Tiger 1321 rebuild
Paul Wills
Has liked: 646 times
Been liked: 142 times
Re: Tiger 1321 rebuild
Post by Paul Wills »
Hi John,
Yes the floor and supports are resin but I have added strength to the floor with L shaped beams and the support arms have metal rods in them. I have moved all the electrics so it will fit in, I even have room to add the rest of the floor. unfortunately it means I cannot add the engine in the engine bay, all the battery's and switches are in there.
Paul. :wink:
Paul Wills
After reading some of the new posts and seeing that one or two of you are detaining the interior of your Tigers, I thought I would share this book. The Research Squad, A Modern Study of Fgst.NR,250031. Its the Early Tiger 1 from the Wheatcroft collection.
I bought some parts for the Cannon balance spring to finish the interior of my Tiger Ausf E, but I couldn't find a really good picture of how it should look together.
So I trawled the internet without success until I remembered this book..... note to self, check you own book collection first :lol:
So if you are looking for images of the early ausf e spring balance here it is.
The parts are not too far out, so I can rejig them into what I want.
Paul. :wink:
Paul Wills
So after nearly two months I have finally finished my early tigers counter balance. Using the parts I had, I reworked them using the pictures in the research squad book I think I now have a fairly reasonable replication of the counter balance.
I Have also finished the gyrocompass from Ivano and added a light.
So I've just got to install everything and it will be back to the Sdkfz7 or until something else catches my eye.
Paul. :wink:
Has liked: 2267 times
Been liked: 7152 times
Great work Paul , can I have one. Now a post at least once a week from you would be wonderful! 8)
Been liked: 1661 times
Some nice extras there Paul, keep at it, once started must finish, regards simon.
John Fitzsimons
Has liked: 5 times
Been liked: 682 times
Post by John Fitzsimons »
Hi Paul,
Great work,
Thanks for posting info on that book. Just ordered a copy. Just getting back to my own tigers. Great inspiration.
Paul Wills
I have been working on the smoke dischargers again and decided it was time I got the smoke canisters made. So I approached Tim Catton for help and this is what we have come up with, I think they look very close to the originals.
There are two types, the Nb.k.S.39 which uses aluminium and which seem to be the early type, and Nb.k.39B which uses zinc. I've gone for the Nb.k.S.39.
If you want to order a crate of 12, drop Tim an email.
_DHQ (1).jpg (96.77 KiB) Viewed 1888 times
DHQ (1).jpg (85.62 KiB) Viewed 1888 times
DHQ (2).jpg (74.19 KiB) Viewed 1888 times
Paul. :wink:
Superb work guys! 8)
