Steen's StuG 3 build thread
- Has liked: 1021 times
- Been liked: 893 times
Re: Steen's StuG 3 build thread
Thank you for sharing images on your build Steen.
We boys like to get a little dirt on our fingers, dont we.
Have a great build weekend Steen, and stay safe.
- Steen Vøler
- Has liked: 62 times
- Been liked: 498 times
That's right Robert
Today's work is over and the following was made
Priming the steel metal parts for the lower hull build
Installation of the bushes
Assembled the hull floor, the sides and some of the lower front and rear parts
Everything is just loosely assembled and not loctited except the bushes.
cheers
Steen
Steen
- Roy Beukeveld
- Has liked: 171 times
- Been liked: 118 times
Hi Steen, you've had a productive weekend for sure, it's starting to take shape, nice!
Kind regards,
Roy
Roy
- Steen Vøler
This is one unsual Stug 3
does anybody know more about this
cheers
Steen
Steen
- Has liked: 1381 times
- Been liked: 1578 times
It looks like a stripped down Flak 38.
Have you seen the other pictures on Facebook ?
- Steen Vøler
Hi Adrian, saw another one with a close-up of the canon, and you might be right here
Moving slow ahead with the build - I have primed some more steel parts - build will continue in the weekend - have a busy work week so not so much in the hobby room
cheers
Steen
Steen
- Has liked: 293 times
- Been liked: 639 times
Looking good.
In the Famo build I've been on from the first. In my StuG build I'll be one of the last... - Loking to have some impressions from you guys
So let your weekend being in your mans cave
- Steen Vøler
weekend is coming in a short time and so the hours to spend in the man cave
Have a question about the hull floor just to clarify the construction principals
To the rear there is a large bolt going in from the side plates to the hull floor. There is not a similar fastening type on the front part.
Will it be the torsionbar alone that secures the sides to the hull floor or am I getting this wrong.
cheers
Steen
Steen
- Been liked: 571 times
Hello Steen,
Yes the ends of the torsionbars will fix the hull plates.
I drill and tap on each side 3 extra holes to fix the hull plates so i dont need to fix the torsion bars
in the begin of my build. The torsion bars i will put later in ( other things to do first )
best regards Yves
best regards Yves
- Steen Vøler
Thanks Yves
I believe this will be a fine solution to fix the lover hull without the torsion bar installed
cheers
Steen
Steen
- Steen Vøler
Sunday afternoon in the workshop working mainly with the suspension stuff and the main sprocket parts
Loctite was the main stuff used here
cheers
Steen
Steen
- Steen Vøler
not much to post - am busy at work, but managed to place the order for the motionpack
cheers
Steen
Steen
That's not the worst thing you could do.
I enjoy following your progress with your build.
- Steen Vøler
thanks Robert
Not a lot going on - really busy at work, but managed to install the return rollers and right sprocket case.
When doing a dryfit of the sprocket case, the gear was not able to turn as it should. unscrew the case and noticed that the gear itself had a slight oval surface on the side facing the side plate. Realized this it was a easy fix. Just used my grinder tool and sandpaper to get the gear 100% even on the surface. 5 minutes after the sprocket case was attached to the side again and fully screwed into place. the gear spins like a cat now
cheers
Steen
Steen
