Has liked: 725 times
Been liked: 332 times
Post by Christoffer Ahlfors »
You designed the Armortek firing device? Awesome! :D
It is the only thing to date to provide the right barrel smoke in the right fashion!
Has liked: 2267 times
Been liked: 7152 times
A very quick video of my high pressure smoker doing it's stuff in the Tiger1 stacks, the sound of the fan is noisy right now but a rubber mount and the engine sounds will fix that. 8)
Something I'm working on right now, fully functionality to! More on those in the next exciting episode.
Balancing the smoke fan, first by drilling the mount centrally something the manufacturer just couldn't get right.
I keep giving all these little secrets away!
Ive been busy making more correct tow cables, just got the track pulling rope to do.
I just had to manufacture the early track hanger that the 503 used, the only compromise is the way I have had to fix the hangers to the front plate.
So the top section unbolts, you slide the track in and bolt it back up. The track cannot fall out as the horns are below the horizontal top piece.
More photos to follow.
Been liked: 1644 times
superb smoker phil, Thats what the bovington Tiger look's like, plenty of thrust and power behind the smoke, regards simon.
Been liked: 1789 times
Masterclass Phil, really enjoying this impressive build.
Christoffer Ahlfors wrote:
Tue Oct 13, 2020 8:44 pm
The last line is not strictly true, there was one other firer built by Winson/Modelworks. It to my knowledge was rarely used due to being rather expensive to discharge. :shock:
Fully loaded it would have cost £40 or there about's, (12x electrically fired maroons). The literature failed to mention that. :lol: :lol: :lol:
Rattled the factory windows when it was demonstrated to me, when the smoke cleared I thought they'd deafened me.
That ugly chap in the advert picture was just pleased to have completed the model before the company started making clocks. :lol: :lol: :lol:
Hi John, electrically fired maroons have their place, I use them mainly for batsims but like you said are expensive and very sketchy to load into that carosel, most have long firing wires so you can be at least 500mm away from the thing when you connect up, that carousel fully loaded had a mass explosive hazard big enough to take your fingers off maybe even your hand.
A little advice for anyone still using the discontinued blank firer, just use the percussion cap without the black powder load, it's still very loud and a whole lot safer.When I post a video of my 331 firing the effect will be huge as this unit is my mk 4, very different from the standard mech.it should rock the whole tank!
Some more progress on 331.
Debrightening the reduced head fixings by simply heating each one to "cherry red".
Dave s wonderful tool clamps.
Imagine how good this will look with Liams steel track links!
I'm making the tool handles from ash and beech.
David Brady
Has liked: 187 times
Been liked: 711 times
Post by David Brady »
Looks good Phil
Lots done. 8)
Turning the detail into the stock hatches.
I'm using Armorpax detailing parts , I just don't have all of them yet.
Setting it all out as I go.
Turning down the front compartment deck vent.
Sorting the tools.
Sorting the tools.
Making those tool handles, this one is for the deck shovel/spade.
The stacks finished and the rain guards working nicely.
Steen Vøler
Has liked: 62 times
Been liked: 498 times
Post by Steen Vøler »
Just love the rain mufflers.
Are they 3d printed
cheers
Steen
Hi Steen, no they are hand crafted from steel. They do look good with the smoke lifting them open and then gently closing as the engine stops, you do need a high pressure smoker for that to happen though.8)
Kevin Hunter
Has liked: 598 times
Been liked: 145 times
Post by Kevin Hunter »
Phil Woollard wrote:
Sat Oct 17, 2020 11:12 am
You know you want to :D
Adding the front deck details, I'm enjoying this build very much it's a good time of the year to be in a cosy workshop. 8)
The stock hatch looks just fine with Daves parts, I'm ordering the rest of the hatch details from Armorpax right now.
The stock hatches do open and sit nicely on the deck.
It's getting busy on that front deck.
You may wonder why I bother taking these little diorama's photos, well they do help me with the build, colour checking, detail considerations things like that.
Steen Vøler
Has liked: 62 times
Thanks Phil, wondering about a radial fan insteaf of the classic fans used on smokers
Could have 2 of them installed, 1 in each side of the smoker box
cheers
Steen
Sounds feasible, give it a go Steen! Generally the worst that can happen is all the smoke oil gets blown out the exhausts.
More done to the deck fittings.
I've been using one of Steve's beautiful creations as reference for my take on the head lights. If you cut them down on the lathe they can be put back together more like the expensive examples.
I didn't have the correct long pry bar so I've made one from steel.
The tow cable brackets are bolted in place, brass wing nuts where ever possible.
The head light mounts have been detailed and the conduit made up both sides, I do like the twin head light early look.
Made up the barrel cleaning rods, the kit pack is very good quality. The head lights have been cut in half, a reflective paint to the inside, a simple lense made, a soft white led mounted and fine screws hold the front bezel in place.
