![Shocked :shock:](./images/smilies/icon_eek.gif)
![Embarassed :oops:](./images/smilies/icon_redface.gif)
The new magnum opus on the M3 by David Doyle has got me all enthused again - it really is a must-have for all M3 owners. So time to get going, with a view to finishing it in time for the next show season (whenever that might be
![Confused :?](./images/smilies/icon_confused.gif)
This was made a lot easier as I'd already glued in all the rivets, and finished the diff case, so it's just a matter of bolting everything together. I'm already calling it "the tub", and it's useful so that I can start to work out where all the modules and the batteries are going to go. Despite the massive height of the M3, I think it's going to be tight in there .............
The other thing that's been worked on is the revised turret. Monique kindly supplied a Grant cupola and hatch, so all I had to do was fit it to the Lee turret. But it's not a straight swap, so I needed help from a friend with a lathe .... I'll spare his blushes, but I owe him a lot.
The key issue is that there's a flange on the bottom of the Grant cupola that is much bigger than the hole in the Lee turret !
My original idea was to cut the flange off. But my friend, being clever, said it would be easier and stronger to make the hole bigger to take the flange:
So, in summary, this is how a Lee turret was designed to look:
And this is how my Burma version looks:
All I need to do is glue it in, cut the slotted bolts down to fit the holes (with are now out of alignment, so will have to be glued - top bodging !
![Laughing :lol:](./images/smilies/icon_lol.gif)
So that's the story so far. Normal service has (hopefully) been resumed. I'm going to try and make some time every day for this, even if I only bolt two plates together. Gotta have a plan ............
All the best,
