A very quick video of my high pressure smoker doing it's stuff in the Tiger1 stacks, the sound of the fan is noisy right now but a rubber mount and the engine sounds will fix that.
Something I'm working on right now, fully functionality to! More on those in the next exciting episode.
Balancing the smoke fan, first by drilling the mount centrally something the manufacturer just couldn't get right.
I keep giving all these little secrets away!
Ive been busy making more correct tow cables, just got the track pulling rope to do.
It is the only thing to date to provide the right barrel smoke in the right fashion!
The last line is not strictly true, there was one other firer built by Winson/Modelworks. It to my knowledge was rarely used due to being rather expensive to discharge.
Fully loaded it would have cost £40 or there about's, (12x electrically fired maroons). The literature failed to mention that.
Rattled the factory windows when it was demonstrated to me, when the smoke cleared I thought they'd deafened me.
That ugly chap in the advert picture was just pleased to have completed the model before the company started making clocks.
Hi John, electrically fired maroons have their place, I use them mainly for batsims but like you said are expensive and very sketchy to load into that carosel, most have long firing wires so you can be at least 500mm away from the thing when you connect up, that carousel fully loaded had a mass explosive hazard big enough to take your fingers off maybe even your hand.
A little advice for anyone still using the discontinued blank firer, just use the percussion cap without the black powder load, it's still very loud and a whole lot safer.When I post a video of my 331 firing the effect will be huge as this unit is my mk 4, very different from the standard mech.it should rock the whole tank!
Some more progress on 331.
Debrightening the reduced head fixings by simply heating each one to "cherry red".
Dave s wonderful tool clamps.
Imagine how good this will look with Liams steel track links!
I'm making the tool handles from ash and beech.
Hi Steen, no they are hand crafted from steel. They do look good with the smoke lifting them open and then gently closing as the engine stops, you do need a high pressure smoker for that to happen though.
Adding the front deck details, I'm enjoying this build very much it's a good time of the year to be in a cosy workshop.
The stock hatch looks just fine with Daves parts, I'm ordering the rest of the hatch details from Armorpax right now.
The stock hatches do open and sit nicely on the deck.
It's getting busy on that front deck.
You may wonder why I bother taking these little diorama's photos, well they do help me with the build, colour checking, detail considerations things like that.
I've been using one of Steve's beautiful creations as reference for my take on the head lights. If you cut them down on the lathe they can be put back together more like the expensive examples.
I didn't have the correct long pry bar so I've made one from steel.
The tow cable brackets are bolted in place, brass wing nuts where ever possible.
The head light mounts have been detailed and the conduit made up both sides, I do like the twin head light early look.
Made up the barrel cleaning rods, the kit pack is very good quality. The head lights have been cut in half, a reflective paint to the inside, a simple lense made, a soft white led mounted and fine screws hold the front bezel in place.
