- AlastairCooke
- Has liked: 16 times
- Been liked: 714 times
Hi Phil
I think it is an early style bin? See Modellers Guide page 76 and 117.
Alastair
Alastair
Alastair
- Has liked: 2267 times
- Been liked: 7152 times
I will take a look Alastair, here's another couple of photos of 331
- Has liked: 6 times
- Been liked: 194 times
Hi Phil,
Not a PzIV bin but an ad hock build probably from a workshop at Fallingbostel.
http://tiger1.info/EN/Turret-bin-503.html
#331 is a good guess just compare the missing flap at the rear LHS mudguard and the ~half broken off last fender allowing all that dirt trown up at the rear end/side.
It´s all in the details!
Thanks guys, good to hear from you Kent, I want to add a lot of the damage and the missing parts ( if that's possible to add missing parts!)
- Has liked: 775 times
- Been liked: 1741 times
I know someone that will be interested in the fillet pieces!
- Steen Vøler
- Has liked: 62 times
- Been liked: 498 times
Well Steen, if you can print them yourself you could ask Vince nicely and he may send you the stl files or I can print them out for you if Vince doesn't mind, I really don't mind as I owe you one?
Don't you just love our community!
- Steen Vøler
Absolutely Phil, its just fantastic
I can print it myself if you are ok with it Vince
cheers
Steen
Steen
- Has liked: 8 times
- Been liked: 697 times
Hi Phil
Great work your doing on the Tiger.
PM sent
PM sent
Now who might be interested in this???
Might be too big to print.
Now I could kiss you but that wouldn't be appropriate let's give it a go Vince.
The top section would need to be separate or the support structure necessary to hold it during printing may prove difficult to remove.
The same goes for the turret lifting lug cut out, that needs printing separately or maybe made part of the top just print inverted with minimal support.
Without the top I see no reason why it wouldn't print very well indeed!
Maybe a lip on the top section so that it would locate nicely into the bottom but with a large tolerance so it will slot in with minimal fetling a bit like the standard T1 turret bin?
Decided today not to binge watch Korean dramas and Japanese anime on Netflix and made the bin instead.
Files sent via email. No guarantees that it will work out. Bin is in three parts. Wall thickness is 4mm to make it sturdy. Suggest you print the main body with the bottom on the print bed to minimize supports. I used the dimensions from the tiger1.info website. Drew it full size then scaled it down to 1/6th scale. The inner radius is 193mm which fits on my turret but I don't know about yours. Suggest before printing anything draw an arc on a paper with that radius and check that it is OK for your turret.
You need to add metal brackets, hinges and a latch.
I will print today, even the real turret bin didn't fit the turret! Great stuff Vince
Hi all,
Interesting!
But please note the turret lifting lug cut out had the bottom plate sloped to drain rain.
Something missed by everyone das far so please lets put an end of it today.
Interesting!
- E5C08911-6A08-46C9-8127-8B3ADDB3C4FC.jpeg (47.5 KiB) Viewed 2059 times
