Has liked: 794 times
Decided to do two empty shell casings. At first I was going to make them with a resin 3D printer from a commercial printer, but then decided to do them myself in brass. The bottom rim should be 18.5mm for 1:6 scale so ideally I should use a 20mm brass round bar which I did not have. I have 22mm but considered it to be too wasteful. So instead used an 18mm round bar and reduced the other shell diameters by 0.5mm to keep the same aspect ratio.
Half way through the first one had a problem with the lathe motor which eventually I managed to fix also. Enjoyed doing them as it's been a long time since I did some machining.
At the moment they look too polished but the look should improve after the brass gets naturally tarnished.
Kevin Hunter
Has liked: 605 times
Been liked: 147 times
Post by Kevin Hunter »
They look good Vince, and half a millimeter?..........if you had said nothing who would have been able to tell? :D
More nice details.
Kevin
Thanks Kevin
Has liked: 749 times
Been liked: 360 times
Post by Christoffer Ahlfors »
Absolutely beautiful! :D
Tarnished? There would not have been time for them to tarnish naturally from manufacture to their use at the front. But perhaps the temperature when firing tarnished them instantly? Perhaps any real tankie here can advise?
Thanks Christoffer.
Has liked: 2282 times
Been liked: 7196 times
They look beautiful Vince, as far as I am aware the tiger shell cases were in fact electro plated steel. Electro plated with a brass alloy. 8)
Has liked: 166 times
Been liked: 849 times
Looks really good Vince. Nice work!
B
mark lawson
Has liked: 2522 times
Been liked: 445 times
Post by mark lawson »
very nice work you have done with the casings they look very good.
A bit of background on 88mm casings; pre-war these casings were indeed made from brass at the beginning of the war this quickly moved onto brass electroplated steel casings by mid war the casings were being released as parkerized steel and also lacquered plain steel. Throughout the war casings were recovered and returned to the factories to be re-charged and re-issued this means that a mixture of casings would have been issued and by 1944 brass casings would have been quite rare the majority would have been the parkerized and lacquered plain steel types.
RAG Militärmodellbau
IG Militärmodellbau
Thanks Phil, Bob and Mark for the nice comments and also for that info about the shell casings.
I knew about the brass and also about the steel casings but did not know about the plated steel variant. Learnt something new.
p.s. Been looking at the King Tiger casings and they are bigger than the Tiger 1 casings.
Marco Peter
Has liked: 1539 times
Been liked: 798 times
Post by Marco Peter »
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
Roy Beukeveld
Has liked: 171 times
Been liked: 118 times
Post by Roy Beukeveld »
Vince Cutajar wrote:
Sun Apr 29, 2018 12:00 pm
Well, this week was passed mostly painting (spraying) the hull exterior. First a coat of etch primer:
Then a coat of red primer:
And finally a basecoat in the required areas:
Hi Vince,
First of all compliments for your fantastic Tiger!
A few questions from a newbie if you don't mind...
In the post I quoted above you show three pictures of the three layers you painted there.
How did you prepare the bare aluminium for the first layer of paint? Only cleaning and degreasing or sanding too? Sandpaper, scotch brite?
And the next layers, paint on paint? Any preparing there or is the spray painted primer surface smooth enough to continue with the topcoat as it is?
Thanks a lot :-)
Kind regards,
Roy
Hi Roy
First of all, thanks for the complement and now to answer your question.
Etch Primer Coat
This was sprayed on a previously prepared surface. All the edges of the part are first deburred. Then the surface is lightly keyed using sandpaper (I used 220 grit) and then the part is cleaned / degreased. I used acetone. Do not overspray as you might get an "orange peel" surface finish. If this happens, let it dry, lightly sand the affected area and respray.
Red Primer Coat
I wait 24 hours for the etch primer to cure and then just spray on the red oxide coat. Where there were large flat areas involved I lightly keyed the etch primer coat using the same 220 grit sandpaper.
Base Coat
I waited 24 hours for the red oxide to cure properly. Areas which were going to be covered in zimmerrit I left them in red oxide. The rest was just sprayed with the base coat. I did not bother to key the red oxide layer.
That's how I did it. Most of the surface prepping was done before the etch primer. Hope this was useful to you.
Roy Beukeveld
Hi Vince,
Thanks a lot for your reply, it sure was helpful 👍🏼
When you lightly key a painted surface, how do you clean afterwards? Just wiping of the dust will do?
Kind regards,
Roy
Yes Roy. I just wipe the dust off with a dry cloth.
Robert Tanzer
Has liked: 1131 times
Been liked: 990 times
Post by Robert Tanzer »
Hello Vincent
Where did you get your loaders hatch?
I have one from Armorpax, but it dont fit. It's to big.
Robert
