Has liked: 2267 times
Been liked: 7152 times
Thanks for the info, I think the warco wm 180 with dro would do the job, why is it that the model you want is out of stock?
That's the biggest stencil I have in stock but have just ordered 50mm and 60mm sets, they are expensive for what they are mind. 8)
Derek Attree
Has liked: 218 times
Been liked: 183 times
Post by Derek Attree »
Hi Phil
I have the Warco 250v with dro and it's a great machine over 2 years.
I have just had a WM 16vs milling machine with dro delivered as well and again it's great.
Hope this helps
Derek that gives me confidence to buy knowing that you guys are happy with the make and models that you have chosen. 8)
Has liked: 1024 times
Been liked: 2094 times
Phil, good advice I was given was choose your lathe and then buy one size bigger. Looks as though Warco have the 240B in stock and it's not that much more, certainly cheaper than the Sealey job:
https://www.warco.co.uk/metal-lathes/30 ... lathe.html
And no, I don't have shares in Warco or any commercial connection, much to the pity.
That's got the bigger Chuck to, I've sent them a question regarding fitting dro to that model. 8)
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
Hi Phil, I have had the Warco 240 for over 10 years, only problem was to replace the carbon brushes in the motor, that’s the only time it let me down, it come with its own tool kit and change wheels
Regards Jeff
I've had a busy but enjoyable day weathering the Chieftain . 8)
Has liked: 132 times
Been liked: 784 times
Phil,
Just stunning on the detail and painting. I like how the tape peeled some of the paint - looks very realistic. If you do ground level photos it would be hard to tell your Chief is not the real deal. You seem to set the bar several notches higher on every build!
Ivano Costantini
Been liked: 735 times
Post by Ivano Costantini »
Hi Phil, I see with regret that the engine has not yet arrived, this morning I had this information from the traceability system:
on day 7, the shipment left the Italian national territory and was taken over by an English postal operator for delivery.
However I think it's an international problem, I still haven't received the bolts ordered on May 26th.
Grazie! Ivano
Ivano Costantini
Hi Phil,
this morning the tracking system tells me that the package is being delivered. Let's hope!
Thanks Ivano
I wonder if that means it is out for delivery today? It's so exciting! 8)
Ivano Costantini
in consegna, translates "in delivery"
Ciao!
Had to basically paint the numbers by hand. 8)
Has liked: 777 times
Been liked: 1745 times
You've got a lot of time on your hand.
Been liked: 1804 times
Frighteningly wonderful, 8)
