Hi all, just started my Famo build ,but when I came to fit the bump stops to the brackets I coud not find the M6 X 10 grub screws.
They are not listed in the fasteners list, are they in a separate bag or not in the kit. Did other builders have the same problem?.
Regards Walter.
Famo Bolts
- Has liked: 8 times
- Been liked: 4 times
- Tom Miller
- Been liked: 347 times
Re: Famo Bolts
Hello Walter,
Well, that is not a good way to start your build. Occasionally Armortek mistakenly leaves out some parts. Usually bolts or other hardware. They are very good about replacing missing parts but I usually just go the hardware store and purchase them. I don't recall those parts missing in my kit.
The FAMO is a challenging build. I think it is much more difficult than a tank model. Have fun with your build.
Tom
Tom
- Tom Miller
Re: Famo Bolts
By the way, since you are at the beginning of the build I would mount the drive motors before you bolt the two halves of the frame together for the last time. I did not do that and while it is possible to mount them later it is very difficult.
Tom
Tom
- Chang
- Has liked: 16576 times
- Been liked: 487 times
Re: Famo Bolts
Hi Walter,
Same thing happened to me. But since it is just a few grub screws. You can either:
(1) If you can wait for a few days, ask Monique to send them to you , or
(2) If you don't want to wait, then go to your local hardwares store to get some.
Regards,
Lerh Chang
Regards,
Lerh Chang
- Has liked: 297 times
- Been liked: 645 times
Re: Famo Bolts
Hi Walter,
Great abother Famo is going alive
Fortunatly al my screws I've got in my Famo.
Well thiy little missing parts you can by online or ask Monique. She is helping verry fast if some parts missing.
Let us see some pictures of your build. Its one of the difficultest Models. Thinking you will have some more questions later.
