Has liked: 777 times
Been liked: 1745 times
Can you reduce the diameter and not the thickness?
My plan would be to build a complete L60
Count me out on the engine.
Has liked: 2267 times
Been liked: 7152 times
Yes the diameter can be reduced and the thickness can stay the same or I can scale it up or down on any axis 8)
The starter plate printed just fine Vince 8) The fan assemblies, I need to double check the space in the Armortek engine bay as it's not to scale, I don't want to print for 19hrs to find they are not going to fit .
I've sorted the turret interior lighting, we have crew compartment lighting, we have light projector, we have NBC fan running all individually switched or all on at the same time
Each led circuit can be dimmed as you like it.
You can hear the NBC fan running which adds to the overall signature of the vehicle.
The diameter of the fans is 93mm and I have a feeling that you will need to down-scale the units like what you did to the starter plate. Best wait till you get the engine and then you have a better idea of what fits and what doesn't.
I was thinking the same thing vince, measuring under the tee piece just now it's around 10mm per side to wide. I think I'll do a draft at 90% as that will be quick and should show up any problems.
The engine has now been posted so should be here early next week. 8)
Can I be a pain Vince and ask you to slice the file 40mm from the top of the coolant tanks right through the fans, that would make for an even quicker evaluation? 8) hang on I need to measure that depth of cut again, be back in a mo! Na it's 60mm not 40mm, I blame the wine!
Did you get that Vince the slice needs to be 60mm?
60mm from the top of the reservoir.
I am not at home at the moment. Will send you the file when back home.
Kevin Hunter
Has liked: 598 times
Been liked: 145 times
Post by Kevin Hunter »
Phil Woollard wrote:
Sat Jun 06, 2020 9:46 am
whoa..... I hope you're inferring a slight hangover, and not that you're drinking wine at quarter to 9 in the morning :D :D :D
Kevin
Wine for medicinal purposes.😀🎉
Of course, drunk in moderation the red variety will keep you young as it contains resveratrol one of the most potent antioxidants known to man!
Just three glasses an evening mind :roll:
Any chance of one of these Kian?
60mm slice sent.
There's hardly any fan parts. Be advised, like on the real thing, that the stator blades are attached to the hub and shroud whilst the rotor blades are only attached to the hub. As there is no hub in the slice, you might have problems with the pieces of rotor blades.
I will have ago Vince, thats when the scaffolding may be a help. Thanks for sending that my friend. 8)
Scaffolding!
Scaffolding!
Been liked: 1804 times
Phil, great vehicles but they don't float as well as you might expect them too.
I've had these two amphibians. 10th ish scale
Of course you'd want the Stolly to be fully working too.
Archimedes theory just doesn't scale as well as you expect once you hit real water. :cry:
Getting out of the water is a lot harder than getting in too.
The Germans made it much easier with the Land Wasser Schlepper 8)
