Engine L60 for Chieftain
- Has liked: 2267 times
- Been liked: 7152 times
Re: Engine L60 for Chieftain
Very nice indeed, how will you show the fan shroud/brackets that the water tanks sit on? They will need to be sliced!
- image00099 copy.jpg (150.17 KiB) Viewed 4319 times
- Been liked: 735 times
On the bottom of the coolant tanks, I created two shims to bring them to the right height (they can be eliminated or lowered if necessary).
The coolant tank is attached to the engine head with a bracket like the real one. I don't know, if that was the question, because I don't quite understand what you mean.
How much of the fans would show Ivano ?
Phil, the fans aren't there,
there is no room to do them.
Anyway, on Wednesday I think I can start assembling an engine before I send you yours. So maybe we understand each other better.
The decals should also arrive on Monday.
Have a nice Sunday
Have a nice Sunday
First cloned pieces.
Do you know the color, RAL code, of the engine?
Colour is British duck egg blue.
Here is the printing test of the plates
I have given the green light to the press, they will arrive next week.
I ordered the bolts this morning.
I hope to ship everything next week, it would be time!
I also inform you about the number of bolts:
M1.4 x 8 you need 195 pieces
M 1 x8 " 4 pieces
You know the prices better than I do.
M 1 x8 " 4 pieces
- Has liked: 1024 times
- Been liked: 2094 times
The Leyland block colour has come to be known as Duck Egg Blue but the official colour reference for Leyland Engines is actually Sky Blue. For the exact hue, its specification under British Standard 381c is BS101. You can see a sample here:
https://www.e-paint.co.uk/Lab_values.as ... Sky%20blue
This morning I collected the last pieces,
if there are no surprises, the engine is complete.
Over the weekend I will send the first one to Phil for the final test.
As soon as I have confirmation that everything is fine, I will be able to tell you the cost. Some photos to evaluate the "out of scale". The drawing is in perfect 1/6 scale.
Clearly, like all my engines, there is the possibility that some parts need to be slightly modified. In this case, I think it may be necessary to "thicken" this bracket. Having no tank, I can't calculate the exact measurement. However, a little plasticard on the sides is enough, nothing complicated.
Looking good Ivano! I will need to move that filler cap on our chieftain as yours is in the correct place
- Has liked: 8 times
- Been liked: 697 times
Ivano.
That looks like a great addition to the Chieftain, can you tell me if the finished kit includes both radiators ?
Hi Steve, I think I can answer that one for ivano, yes it would contain both radiators, I may be able to offer the gue slice and the main engine ancillary parts slice also, just don't know what will fit as yet but will know soon!
