- Has liked: 2267 times
- Been liked: 7152 times
For you ivano, I think I'm going to have to cut out the triangular section in the deck as it's annoying me somewhat.
- Been liked: 735 times
Hi Phil,
I'm sorry, but maybe, at the beginning, you didn't foresee those details under the radiators.
From the last photos you posted, you have the left radiator.
It will cost € 30 more but better with metal bolts. That's about 200.
Worth every euro Ivano , your legacy, our legacy will live on my friend even after we have gone !
- Senza titolo (2).jpg (71.23 KiB) Viewed 3788 times
- Radiatori 6.jpg (39.93 KiB) Viewed 3788 times
- Has liked: 777 times
- Been liked: 1745 times
It's better to fabricate the brackets yourself depending where you intend to attach them.
Beautiful interpretation of my crappy drawings Vince!
Been busy in a baking hot workshop.
For vince, those prints look perfect! I'm getting ready to hopefully see the NASA Spacex craft fly over the west country here in the UK a 21.50 tonight on its way to the space station.
That is amazing vince!
I've been busy making parts and detailing the fire wall.
Last edited by Phil Woollard on Thu May 28, 2020 2:43 pm, edited 2 times in total.
I guess all those bits and pieces add up to make a whole picture.
You got it! I'm using the limited cad adjustment program to change the shape of the stl file subjects to make all manor of different things, you just have to have a good imagination.
I'll print that lovely injector unit as soon as the printer is free and post it for you. I have to drill everyone of those high pressure outlets to accept 1.5mm wire to represent the pipe work.
Maybe this could be a useful read. How to edit stl files.
https://all3dp.com/1/7-free-stl-editors ... stl-files/
Obviously when doing something like this, always use a copy of the original stl file just in case everything goes belly up.
There you Vince just the job, shame about my kindle camera .Thank you so much for your help today
More progress on the firewall. I should get the main engine from Ivano sometime next week.
