- Has liked: 2267 times
- Been liked: 7152 times
Then I shall print straight from the file!
All done and it looks perfect!
- Has liked: 777 times
- Been liked: 1745 times
Just finishing up the sketch of the gue Vince, it's only going to be a 20mm slice but if we can cad the whole thing then we can use it for diorama work.
The Jack looks nice!
- Has liked: 1024 times
- Been liked: 2094 times
Phil, Vince, you asked me for plans of the GUE. These are the best I can do:
Many thanks for those Stephen, Vince I've sent the sketch with basic dimensions but now we have the drawings from Stephen I think it will fall into place......I will leave it in your capable hands!
It looks like there were different versions to, so that gives us scope!
- Has liked: 270 times
- Been liked: 324 times
I do not recall ever seeing a bottle jack kept and used on a tank but most of my experience was supporting Challenger 1 & 2. On them if a roadwheel had to be replaced, a strut plate was used. Curved surface at the top which went under the stub axle and two teeth at the bottom that went into the track ( where the inner sprocket teeth would go ). Moving the tank a little bit would then lift the stub axle up allowing the wheels to be changed.
Maybe this strut plate was a later idea and was not available on Chieftain.
Although a crew job, my experience on exercise was that the fitter section would assist with all available manpower if we were not involved in other taskings. We wanted maximum number of tanks operational between us and any enemy.
When you break it all down you have a three cylinder diesel, so the block, the head, the sump are all boxes. Then the generator is a cylinder off the back, it looks like there is a super charger at the back next to the sump, another small box. The starter motor is the cylinder nr the top.
Then we have the diesel pump and injector unit, diesel prefilter and secondary filter.
I would ignore all the hoses and cables and pipe work, that's my job.
I will have a go at printing that bucket of yours vince, it should work on extra fine!
- I've never seen this side before!
- Screenshot 2020-05-22 at 12.04.15.jpg (198.03 KiB) Viewed 1327 times
- Been liked: 735 times
Hi Phill,
here are the correct covers and magazines.
Now I like them more.
The writings are deliberately oversized, otherwise they would not have been seen.
Ivano
Ivano
I recall that the generator was bolted on the back of the engine, and the starter motor for it was mounted low down at the side.
I am not going to do a whole engine. Even looking at it gave me a headache. Plus, it's too complicated for me. I finished the basic shape as per your pencil drawing the rest is up to you. After all that's what I agreed to do.
If you tell me where you want me to slice it I will then send you the file.
I can do something with that vince, could you just square off the top of the engine please, the big radius is fine up to and including the starter motor bracket, so the top of the engine is flat until it gets to that bracket, maybe just 15mm of radius. Sorry it's my crappy sketch that's the problem!
The slice is just 22mm from the very top of the engine, this unit has a dirty great radiator sat on top of it!
Is this OK??
The blue line is showing where the 22mm slice will be. Is that OK?
Yep that's looks great.
I have just posted a short video of Adrian's excellent smoker control unit, this uses the sound of the engine rather than voltage from one of the main motors to energize the smoker fan, so you can play with the revs ( so long as you set the sound module up in a particular way) which ever stick you might be using.
My kindle just won't let me give you guys a link so if some kind soul would I would be so grateful!
Two files sent. One is a 22mm slice and the other is the whole gue shape.
I'm printing as eating curry at the same time!
try this link for the smoker test.
