Calling Armortek from the US
Rich Stinchcomb
Has liked: 3 times
Been liked: 1 time
Post by Rich Stinchcomb »
Does anyone from the US have the complete phone number to call Armortek (including country code)? I just can't seem to get it right. :oops:
Rich
"All you saw in your imagination was the muzzle of an 88 behind each leaf." - British Tank Commander Andrew Wilson
Been liked: 3695 times
Hi Rich
If you e-mail me your number I will be happy to give you a call.
Gill
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Hi Rich,
You should be able to call Armortek by using the country code 0044 and dropping the first 0 of the telephone No ie [0] 1404 892956.
Therefore the number you will need to dial is :- 0044 1404 892956.
Fingers crossed this should work.
Steve.
Rich Stinchcomb
Has liked: 3 times
Been liked: 1 time
I used this number:
011 44 (1) 1404 892956
011 is a country code for what we use in the US for the UK
(1) I used this because (0) didn't work and my Mom uses (1) to call my Aunt in Norwich.
I got someone with a British accent but didn't know about Armortek. :roll:
Gill - I'll send you my number via email, but I'd to be able to sort this out so I call you as well. I've called other numbers in England before so this should be easy.
Rich
Hi Rich
I believe the number you need to call is:
011 44 1404 892956
I think you had one to many 1's :)
Try this tomorrow ( I am not on this number at the moment) and hopefully this will work, if not I will call you on the number that you e-mail
Gill
Steve Norris
Has liked: 8 times
Rich
Sorry for the duff information.
Steve.
Roland Wallick
Post by Roland Wallick »
Rich if you call them use the 10-10-987 then their number. It will save you a bunch. I think its like .53 then .04 a miniute.
Its the only use Ive ever had for those anoying 1010 numbers.
The country codes get confusing, and where to put in the 0
If your not living on the edge, your taking up to much space.
