Has liked: 777 times
Been liked: 1744 times
Thanks Stephen. I am keeping all my fingers crossed that they might work out at the end.
Sent 11 individual stl files.
Has liked: 2267 times
Been liked: 7152 times
It ok it's just come in!
:D
Starting on the rear hull details.Vince I have had to reduce the size of the sterling by 20% as it looked a bit on the big size but no big deal. 8)
Nr side locker contents are coming on.
Grenade basket box, I need to change those fixings for reduced heads.
Making a start on the armour pieces to cover the panniers voids,
I have used longer m5 bolts and turned a taper to help with the turret locating holes.
Helmets all done and weathered.
Kevin Hunter
Has liked: 598 times
Been liked: 145 times
Post by Kevin Hunter »
Great detailing Phil. Those helmets in particular look so like the real thing.
Loving it.
Kevin
Has liked: 132 times
Been liked: 784 times
Amazing details on your Chieftain - simply stunning. I really like the camo colors. Those helmets look like the real thing. You and your team of elves have worked round the clock on this project and it is fantastic.
If you'd like to have a go at resin printing (Vince) send me the Sterling files. I'd like to see how a small detail thing like that prints. Not to take anything from Phil's printing ability of course! A comparison of FDM and resin printing would be fun! One large Zip file would be ok with files in mm.
Awesome work!
Thanks Kevin, Robert I think the stirling would work even better using the resin medium but that's up to Vince. I'm struggling with the fine detail but it's coming on.
Now back to the big oily thing, those vents in the inner panniers that sit opposite the air cleaner biscuit are on my list today, I bet my positioning and ivano's are going to be different, so I'm going to build the vents separately so they can be slid back and forth and up and down, I will just tack them for now until the engine arrives from Italy. 8)
Screenshot 2020-05-05 at 09.54.46.jpg (120.33 KiB) Viewed 540 times
Screenshot 2020-05-05 at 09.52.02.jpg (89.83 KiB) Viewed 540 times
I am not surprised at all Phil. I will send the files to Bob so that if he wants he can give it a try but something tells me he might struggle also with a liquid resin printer.
Just out of curiosity, is it the main body which if giving you difficulty? If it is I can reduce the detail by inserting plugs at the front and back and just leave a silhouette, of the details as can be seen below.
I can also virtually assemble the Sterling and send you the stl of a fully assembled Sterling.
Hi vince, the stock was being a pain but I think I have that sorted now, the body is causing problems so let's try that mod that you suggest ? Or let's try the fully assembled?
It needs to be 80% of the original size to be nearer 1/6 th scale to. 8)
OK Phil. I will assemble one with the modified body. Also do you want it with the magazine or without the magazine? Also shall I leave the stock off so that you can add it later in what configuration (extended or closed) you want?
Oh well. I did not have any dimensions to use as a reference. Yesterday I found a user manual for the Sterling which says that with the butt folded the length of the body should be 48.2cm. It's good to have a scaling function in the slicer.
Maybe leave the magazine out as the weapon will be stowed, and we could try a print to include the stock but folded, again as the weapon will be stowed. 8)
Sent you one with modified body but no magazine and no stock and another one with folded stock and no magazine.
I'm printing away like crazy but leaving the printer after tea breaks does mean you sometimes come back to spaghetti!
I've been working on the engine compartment, the armour for the inner panniers has gone well along with the false floor.
Question for ivano, are you going to offer the gearbox compartment, and do you have dimensions of the engine exhausts, ie the height and the centers so I can start on the expansion box above the gearbox ?
Lots of support on this print Vince, I have just ordered some grey filament as I'm not that keen on this translucent one. That's a two hour print On extra fine.
Just setting out odd parts to get a feel of where it's all going to go.
That a nice big clean flat blank canvas. All these sections have to be bolted together in a sequence so it can all be taken apart and removed for maintenance of everything underneath.
