Does anyone from the US have the complete phone number to call Armortek (including country code)? I just can't seem to get it right.
Rich
Calling Armortek from the US
- Rich Stinchcomb
- Has liked: 3 times
- Been liked: 1 time
"All you saw in your imagination was the muzzle of an 88 behind each leaf." - British Tank Commander Andrew Wilson
- Been liked: 3500 times
- Has liked: 8 times
- Been liked: 697 times
- Rich Stinchcomb
I used this number:
011 44 (1) 1404 892956
011 is a country code for what we use in the US for the UK
(1) I used this because (0) didn't work and my Mom uses (1) to call my Aunt in Norwich.
I got someone with a British accent but didn't know about Armortek.
Gill - I'll send you my number via email, but I'd to be able to sort this out so I call you as well. I've called other numbers in England before so this should be easy.
Rich
Rich
Rich if you call them use the 10-10-987 then their number. It will save you a bunch. I think its like .53 then .04 a miniute.
Its the only use Ive ever had for those anoying 1010 numbers.
The country codes get confusing, and where to put in the 0
If your not living on the edge, your taking up to much space.
