Has liked: 2267 times
Been liked: 7152 times
Lovely dave , was your workshop hot today mine was very sticky indeed. I have the shelf next to the commanders position all ready for the boiling vessel. 8)
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Mines been lovely but that could be the air conditioning :-)
www.armorpax.net
Richard Goodwin
Has liked: 294 times
Been liked: 291 times
Post by Richard Goodwin »
Impressive stuff Phil, am in awe. Keep it going! :mrgreen:
Busy working on the various turret systems, associated cabinets and racking for the ammunition, there are many cabinets for the electrical systems, I don't have the room in there or the time to make and add them all, so I'm picking the most prominent for extra attention and grouping the others together where they are not so visible, concentrating on those in full view with more detail and where I can illuminating with leds. 8)
For Vince, a simple version of these.
For Vince, a simply version of these.
For Vince, the breech would be great.
For Vince, these are important.
DSCI0062 (1).jpg (128.77 KiB) Viewed 436 times
For vince, these would be great.
The 3d printer is working flat out printing shells, I use my tea breaks to clear the finished shells and print more while I'm in the workshop
I will just keep working round methodically.
Has liked: 776 times
Been liked: 1743 times
Phil, I am not like you. I cannot picture these things unless I have sizes to work with.
I cobbled up this storage space for the short sabot because I saw what you are doing and I know the dimensions of the sabot but have absolutely no idea if it's too large or too small to fit where you want it. You know where something like this will fit but I don't and that's the problem.
Has liked: 1024 times
Been liked: 2094 times
Phil, Vince, impressive details really add to the model. Great stuff.
One small point, you would not have seen APDS (or DS/T) in the turret at the same time as Fin projectiles. The stowage was incompatible. The "Improved Kinetic Round" upgrade programme ran in conjunction with the introduction of IFCS in the early eighties and created a series of Marks with the suffix /7 as in Mk 7/4, which was an upgraded Mk 5.
Also, to make it easier to describe the two different rounds, the smaller proj was referred to as "Sabot" and the big pointy one as "Fin", for obvious reasons.
Thank you Stephen, we will stick with the sabot and hesh rnds then. Vince if you tighten up the distance between the rounds then that would be fine!
What do you think about the small double sabot rnd holders, there the ones that sit around the turret ring, again they simply hold 4 rnds in pairs this time vertically but are like open crates? I can give you basic w/d/h dimensions if that helps but I'm only guessing?
None of these examples need to be very accurate as the model turret interior is way smaller than the real thing! 8)
These are very important for the short "sabot" rnds I think the 1pair single units would be best.
DSCI0062 (1) (1).jpg (128.77 KiB) Viewed 401 times
I don't mind doing something like that (keeps me away from binge watching Japanese anime) but I need to have more information.
By saying
is not enough for me. If you say that it has to have a particular width, height and depth than that is giving me most of the info that I would require to avoid redoing the same part many times. A simple pencil drawing with some numbers is all that would be required.
Phil, stowage of ammunition was the preserve of the loader, who practised a black art to get it all in. There were standard bomb loads and diagrammes to follow but a good loader would probably freestyle it to suit the operation and his preferences. Here are the three standard loads for the Mk 5. As you can see, the turret proj racks would have a mix of HESH and APDS (or in training, SH/P and DS/T), which would allow you to show off all of Vince's designs. Trust this is helpful.
Stephen that's just what we need! Vince I will get you those dimensions tomorrow morning as I have now started to cook my dinner and have nearly finished my first glass of red! It's the only way I can wind down you know lol 8)
Just for fun made it smaller. Still not sure if needs to be smaller though. Added sabot rounds for detail.
that looks better, I will get those dimensions to you asap!
Email sent Vince. 8)
Here's the first one. I did not do the thin bar at the front as I thought it would be easier for you to use plasticard. I don't know if it will 3d print ok with those huge cutouts on the side. If it does not print properly, I guess another option would be to redo it without the cutouts and cut them out yourself. Will be sending the stl via email.
