This is how I achieved the above. Using the pictures provided by John and Stephen in their blogs, I estimated where to cut the base of the rear plate.. When the cut was complete, it was filed flat and level; later on, the bottom edge was to be filed at an angle which matched the angle of the angled plate.
In an earlier post, I described how I straightened the floor so i won't be describing that again.
Using the measurements provide by John Clarke, a cardboard template was made of the angle plate and a check of fit conducted. Any adjustments necessary were made. Once happy, I transferred the template shape onto a piece of 4mm plate adding a further 5mm to the depth to allow for an overhang of the rear plate and to allow for any small corrections that may have to be made as fixing progressed. Using a jigsaw, the angled plate was cut out, filed flat and a trial fit conducted. Note that all edges of the angled plate were filed square to the faces! With the angle plate in position, the cutting lines for the floor were drawn, the floor removed and the cut appropriately using a jigsaw. Note, if using a thick marker pen for the cut lines, ensure you cut on the back of the line and not the front! The floor was then finished off by filing smooth. And another trial fit was conducted The original brackets which secured the floor to the rear plate were then used to secure the rear plate to the angled plate after first being opened up slightly to match the angle appropriately.
The cut off pieces of floor were used as templates themselves to make identical plates but this time in 4mm plate. These two 'front plates' would strengthen the floor, provide support to the front of the angle plate and to provide a suitable level to assist with fixing brackets as can be seen in the finished pictures. They were secured to the floor using 4 M3x12 csk bolts having first had a coating of Loctite 648 on the underneath to give a strong bond to the floor plate.
On the subject of brackets, six were made from some 19x19x1,2mm cabinet fixings; they were squashed flat in a vice and then angled accordingly The brackets, three per side, would join and secure the floor the angled plate to the front plates and the the floor plate; the end result of which is shown below I did have to reduced the head diameter of the bolts used to secure the brackets to the rear plate and the angled plate which resides just above the overhang. This was needed to allow the angled plate to sit flush with the rear plate. I will be changing out the normal M3 washers used in securing the cabinet brackets for M3 penny washers to spread the load more and I may consider using Loctite 648 as well to provide even greater strength. I also need to file down the overhang; I was thinking of leaving around 2mm; this should allow room for some weld beading as well. Any comments on this?
So the above is my version of how I've done the rear end mod. I probably put far too many fixings in it but I will say, it appears rock solid
Lastly, stay safe people; its very dangerous out there right now!
