Martin's Elefant
- Martin Hofmann
- Has liked: 151 times
- Been liked: 1995 times
Re: Martin's Elefant
Now i start with the hull and the bottom plate with all the covers and the additional plate in the front of the Elefant.
Regards Martin
- Has liked: 746 times
- Been liked: 359 times
There was a discussion regarding the exhaust a while ago. It is quite clear in your drawing.
- Martin Hofmann
Hi Chris,
the exhaust is in the near of the 5th road wheel. Here comes a photo from the under side of an Elefant how you don't see normally.
Also good to see all the covers in there place - if available.
- Elefant unten.jpg (123.53 KiB) Viewed 6369 times
Regards Martin
- Martin Hofmann
There was some more progress at the hull with all the camfers for welding preparation and with all the bottom plates
Regards Martin
- Has liked: 82 times
- Been liked: 170 times
- Martin Hofmann
Hi Rolf,
thank you for your: Lecker
Here are the next photos of the bottom plates and the camfered bolts for the first big plate. The holders for the joints of the road wheels on each side looks slowly like the origin ones. There has to be made some egalizing and weldings with Milliput.
Regards Martin
- Martin Hofmann
- Martin Hofmann
And here the next photos with all the welding seams and the mounted periskopes.
Regards Martin
- Marco Peter
- Has liked: 1527 times
- Been liked: 797 times
- Martin Hofmann
Hi Marco,
thank you for the nice comment. Here are some more progress on the hull with some Milliput for the bearings of the Road wheels.
After this there are the first impressions of the tow hooks with some additional sheets and the first welding seams.
Regards Martin
- Been liked: 1767 times
very nice attention to detail martin, should be a lovely vehicle when finished, regards simon.
- Has liked: 8 times
- Been liked: 701 times
- Martin Hofmann
Hi Simon,
hi Steve,
thank you for your nice words! Here some more eye catcher.......
hi Steve,
Regards Martin
- Martin Hofmann
- Has liked: 790 times
