- Has liked: 2267 times
- Been liked: 7152 times
I have now installed the drivers compartment, connected the various circuits and it all was working well, went and had a cuppa came back, fired up the engines and nothing! The sound module has decided to not make a sound, there's voltage getting to it but no beep when I switch on and no sound selection, any one have any ideas? Everything else is working at is should.
I'm not going to break the warranty seal so I reckon it's back to Armortek for a check over, thank God they are so good with this type of problem!
As I was at a loss I've made a start on the Armorpax oil containers , helmets and water cans before I start on the turret proper.
- Been liked: 1654 times
Great build, industrial speed construction, always worth checking in on, regards simon manning.
- Been liked: 39 times
Who wouldn't like an 'office' like that? Pure 1/6 scale crewman pampering.....
Marcus
Marcus
Now to the turret.
- Has liked: 34 times
- Been liked: 26 times
Cheers Steve they are the best I've seen!
Smoke discharger brackets, as usual there are a few variations but I have gone for the batus mk5 compromise.
- Been liked: 1799 times
They are really very good Phil. Like em
More turret progress
Turret progress. I have a few smaller parts missing but Monique is on the case!
- Has liked: 116 times
- Been liked: 1106 times
Hi Phil,
Following on from a post on another thread by Stephen about wording and inferences...........is the extinguisher way too long? or is it just longer than where you would like to sit it? If its the former I'll see what we can do before the production mould, if its the later could you change your statement a little
Wiper mould landed back with me today so all being well vulcanised this weekend, sprues cut in during the week and ready to start casting later next week.
Dave
Dave
www.armorpax.net
Good point Dave, someone would need to measure and scale the antenna box to ascertain the correct dimensions of that before I could comment futher, I'm sure Stephen knows the correct length of the extinguishers . I'm just looking at reference photos and adjusting the mounting points to suit your beautiful pieces
- Has liked: 1024 times
- Been liked: 2094 times
Dave, Phil,
My master for the BCF fire extinguisher was scaled from the real thing.
Hi Phil
Some images of the TUAAM box the antenna base sits on.
Not much to report, been building the turret kit locker. I will fit tomorrow .
Thanks for those photos Steve, the antenna box comes in various configurations, some are made from folded steel, some with welded seams, some welded to the turret like the later Mk above with stillbrew and some with a standoff mounting, I have gone for standoff mk5 type.
