Re-release of the King Tiger - End 2019
Scott Boyd
Has liked: 45 times
Been liked: 23 times
Re: Re-release of the King Tiger - End 2019
Post by Scott Boyd »
Nigel Cooper
Been liked: 11 times
Post by Nigel Cooper »
a couple of shots of my KT
61444388_10217559630796293_5553826196187250688_n (2).jpg (155.81 KiB) Viewed 4230 times
Fabian Bekkers
Has liked: 190 times
Been liked: 120 times
Post by Fabian Bekkers »
Kt was taken over by the Americans
Huzaren prins Alexander 🫡
Mike Conley
Has liked: 224 times
Been liked: 181 times
Post by Mike Conley »
Question: Are the new 2019 King Tigers still going to use the brass turret rings or are they going to have the ball bearing rings?
I've just started to build a 2009 King Tiger and am going to order the NEW Motion Pak (with the new style motors) soon and if ball bearing turret rings ARE available I'll order one of those also.
THANKS! Mike (the one in Kentucky!)
Fabian Bekkers
Hi Mike my kingtiger is a 2013 model with a brass turret ring :D
Has liked: 1480 times
Been liked: 1686 times
You might also need a new turret gear and spacer - have a look at Steve Stuarts retrofit of the lazy-susan to a Tiger I.
It ought to be worth Armortek putting a retrofit kit together for the older KTs, as the lazy-susan bearing must make a significant improvement on the ease of rotation of a turret as heavy as the KT.
Mike Conley
Hi Fabian and Adrian!
Yeah, I can tell just how HEAVY this KT turret will be! I was curious IF the ball bearing ring has already been introduced. Since it hasn't, I feel 'sorry' for the traverse motor because this turret is a BEAST! I'll just have to load it up with grease and hope I don't have to turn it much...
Mike (the one in Kentucky)
Peter Quambusch
Been liked: 1045 times
Post by Peter Quambusch »
Hi Adrian, Fabian and Mike,
This is my solution to the problem. Installed it in 2011 and had no Problems since.
Peter
Been liked: 3697 times
Mike Conley wrote:
Sat Feb 15, 2020 1:29 pm
Sorry for the late reply Mike - the 2019 King Tiger has ball bearing rings (similar to the one you have on the M3 Lee -- only a bit bigger !)
Kian
Mike Conley
Thanks for the info Kian!
I'll order the ball bearing ring when I order the NEW style Motion Pack (which should be about the first of next week).
I'll just shave off the two 'half moon' areas in the upper hull deck halves until the inner ring has clearance, then drill the holes for the ring and bolt'er on!
And where did you get those ball bearing inserts Peter? THAT looks interesting also.
Thanks Again Kian! Mike (the one in Kentucky!)
****THIS IS ABOUT AN HOUR after my post above and OOHHHH, I don't know about me getting the 2019 ball bearing ring... I started thinking on it and feel that would probably open up a 'Can of Worms' that I hadn't planned on! If the bearing ring is that much larger in diameter then that would change the location of the 2009 traverse motor location! And what Adrian said about the spacing down or up of the drive gear/spacer and maybe needing both new? And a bunch of other perferentials I ain't even thought of yet! I think I'll have another bee.. er, a, ICE COLD BEVERAGE and think about it but I'll probably go with what Peter did and use 12 bearings in the deck.
Peter Quambusch
Hi Mike,
I got them from a friend, you owns a tool maker shop. They are heavy duty stainless steel bearings. Not cheap, but worth every penny. I installed them on all my older (pre lazy suzan) AT tanks (Tiger 1, KT, Panther).
Peter
Has liked: 161 times
Been liked: 830 times
Mike
You can search around but this may work for the ball transfers like Peter used. I have not tried these, but seems like a good option on older models where retrofit of the ball bearing ring would be difficult. The ball is 5/8" and flange about 1" - about the right size if the height would work.
https://www.mcmaster.com/2415t13
Or this, which is described as a press fit (although I don't see what presses where from their drawing)
https://www.mcmaster.com/6421k41
Chang
Has liked: 16549 times
Been liked: 487 times
Post by Chang »
For Peter's ball bearings solution, I have used it after reading his message back then:
viewtopic.php?f=16&t=3936&start=15
No further modification required.
Regards,
Lerh Chang
Mike Conley
Good Morning Peter, Robert, and Chang!!
THANKS for the info! I'm going to go with those 'flanged ball bearing transfer' bearings, just have to figure out the size. As Robert showed, McMaster has some that looks the size. It'll be a while until I get to that part of the build so I'll have a lot of time to figure it out.
THANKS AGAIN! Mike
Peter Quambusch
Howdy Mike,
Here are the dimentions of the bearings I used:
Ball bearing dimensions:
Dw (mm): 8
D (mm): 12,6 +-0,055
D1 (mm): 17
h (mm): 4,8 +-0,15
H (mm): 11,2
a (mm): 1,8
b (mm): 3,2
max. load(N): 100
weight(kg): 0,007
Holes in the deck are "press fitt", thus no glue is needed!
Peter
