Tiger build
mark j. radick
Has liked: 394 times
Been liked: 538 times
Re: Tiger build
Post by mark j. radick »
simon_manning wrote:
Tue Jan 14, 2020 9:40 pm
Great looking Tank, excellent finish so far, regards simon manning.
Thanks Simon !
mark j. radick
Re: Tiger build
Set up MG linkage..just need to hook up once control panel is complete
mark j. radick
Re: Tiger build
I'm using this linear actuator for barrel elevation... it is very strong...I just don't want to mess around with limiting switches..these are great and plug into the receiver like a typical servo...........
Specifications
Peak power point: 75N @10mm/s
Peak efficiency point: 38N @15mm/s
Max force (lifted): 100N
Back drive force: 46N
Mass: 56g
Positional accuracy: 0.3mm
Max side load (extended): 40N
Feedback potentiometer: 9kΩ±30%
Input voltage: 5-7.4V
Stall current: 650mA
Last edited by mark j. radick on Wed Jul 13, 2022 3:39 pm, edited 1 time in total.
mark j. radick
Re: Tiger build
Now you see it........
mark j. radick
Re: Tiger build
Now you don't.....
i would have liked to place the switch panel under one of the rear hinged grates but removing the Feifel filter ducting would of been a hassle...so I mounted the switch panel under the machine gunners hatch but I made it so it could swivel out of the way, this way I could place a figure there if I desired and no interference with periscope..
Peter Silcock
Has liked: 60 times
Been liked: 33 times
Re: Tiger build
Post by Peter Silcock »
Fantastic build there Mark - beautiful bit of engineering. One question - is there any particular reason you are using a separate battery for the radio equipment, rather than a simple battery elimination device?
mark j. radick
Re: Tiger build
Peter Silcock wrote:
Thu Jan 30, 2020 1:17 pm
Thanks Peter !..the reason is I have many RC components left from my RC flying days including a box full of heavy amp batteries ! the more Mah...the better !
Last edited by mark j. radick on Tue Nov 22, 2022 4:02 am, edited 1 time in total.
Has liked: 746 times
Been liked: 359 times
Re: Tiger build
Post by Christoffer Ahlfors »
What happens if you switch the power to the radio off (everything else on)? I have set my failsafes, but if the radio fuse goes, that's a scenario I haven't tested...
mark j. radick
Re: Tiger build
Christoffer Ahlfors wrote:
Thu Jan 30, 2020 8:00 pm
Always set the failsafes ! a blown fuse ..bad switch ...you can pull your battery out and it should go into failsafe...when the signal is lost no matter the cause
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: Tiger build
Post by Steve Norris »
Hi Mark
I like you idea having the control panel swing out of sight. If you don’t mind I may try a similar set up when I get round to my Tiger.
mark j. radick
Re: Tiger build
Steve Norris wrote:
Sat Feb 01, 2020 10:52 am
Hi Mark
Go for it Steve ! and post plenty of pics ! :D
mark j. radick
Re: Tiger build
Installed linear actuators and linear bearing. I doubled up on the actuators for extra strength and holding ability...worked great even with a 5 pound weight hung just behind the muzzle break and no counter weight needed...plus having the same control as a standard servo like servo travel and speed...also working on a blank firing system
Last edited by mark j. radick on Wed Jul 13, 2022 3:40 pm, edited 2 times in total.
Has liked: 161 times
Been liked: 830 times
Re: Tiger build
Really cool additions Mark, following with interest. Those actuators make for simplified mechanism for sure. Will be interested to see your blank fire, recoil ideas.
Has liked: 1481 times
Been liked: 1687 times
Re: Tiger build
That looks like a very robust and yet simple system :D
I would caution against having anything which sits down below the level of the turret, as it makes it a pain if you have to take the turret off "in the field", unless you have some form of frame on which to sit it.
Re: Tiger build
Ah, beautiful simplicity! :D
