- Has liked: 2267 times
- Been liked: 7152 times
Umm ebay looks good only problem is scale thickness may be to floppy, I will have to order different thicknesses and report back. It must hang right or it will not be convincing.
The rest of the hull camo is now applied, the first coat of wash also applied, I'm just about ready to install the motion pack for a trial run of the oily bits.
- Brian Ostlind
- Has liked: 971 times
- Been liked: 2066 times
My pleasure Brian. A question for Armortek, do we need to fit an isolation switch between the batteries and the power module, I am thinking not with the new power module switch and relay? I'm liking the new module system it should be popular!
- Has liked: 775 times
- Been liked: 1743 times
She lives, and she bites so be careful. This is a heavy powerful lump but we like that!
These new modules are really nice and a lot easier to install and set up than their predecessors. I have just loosely placed the power and sound module in the hull, along with the batteries to see where it's all going to go. I think the batteries will live in the centre of the hull directly under the turret but missing the turret turn motor ( which I shall install next as it protrudes down a fair way).
This Chieftain has every option plus a few of my own so it's going to be tight in there, my high pressure smoker is not small and I may try some more sophisticated speakers, that along with a drivers seat, controls and driver the front compartment is taken up. Then there's the half engine, gearbox, fuel tanks and radiators.
- Setting up the sounds, follow the instructions to the letter, you may need no you will need to enter the set sequence more than once, I did this half a dozen times before it would function correctly. Just keep going through the process as many times as you like as you can't bugger it up. A tip , when your setting/learning the throttle inputs for the sound module, use the opposite direction input for the full throttle learning input. For some reason it works for me.
- I'm going to use the two stick configuration as it's less problematic, and although I do like the one stick control, I feel it's more realistic using the left right stick set up, I think this preference stems from my target drone flying days when we were taught to imagine that we, as the pilot, we're actually sitting in the seat, some may disagree.
I'm so glad that I cut the T piece out, I am shuffling it all around right now trying to get it all to fit.
If you type in "Armortek Chieftain sound trial" to YouTube you can have a listen to a quick unedited video. I can't do a link from this device.
- Has liked: 1421 times
- Been liked: 1598 times
Thanks Adrian! I will post a better video as it all comes together.
- Steve Lewington
- Has liked: 8612 times
- Been liked: 285 times
Hi Phil
Love the video clip outstanding work mate on the build blog
Many thanks
Many thanks
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
No respite.
No forgiveness.
Phil,
just watched the video clip and its superb! You must be well chuffed with the result. The sound quality is the best....
Keep up the good work
Cheers Phil. I have started on the turret as I need to check on the turret interior mechs protruding into the hull, and they do protrude into the hull a tad so careful planning is needed to get the clearance necessary.
One other photo of the finished elevation mech with all its parts fitted
- Been liked: 1798 times
I do like that speaker box you've used behind the motors, you can pick them up for £20 S/hand on fleabay. 100w too.
I bet you can probably wind up the amp volume up to 11 now instead of the meager 7
I'm not saying anything John!
Been sorting the high pressure smoker plumbing and new control circuit for the big fan, that's 60 watts of suck or blow, which ever way you want to do it.
