Daniel Brooker
Been liked: 2 times
Post by Daniel Brooker »
Loving those fender lights nice addition can you recommend which lights you are using for all your lights and a good place to purchase them?
As ever in awe of this build
Dan
Has liked: 2272 times
Been liked: 7154 times
Hi Daniel, ebay, warm white 12v pre wired with mounts, (you may need a voltage converter dc/dc 12/24v step down module also found on ebay, very cheap. Your motion pack may have a 12v outlet) you chose the physical size, say 3 ,5 or 10mm dia . 8)
I've cut the T piece out, more on that later. Oh and nothing moved absolutely nothing! 8)
florian rudolf
Has liked: 297 times
Been liked: 642 times
Post by florian rudolf »
Another excelent work from you Phil,
where do you get the letters to glue on parts?!
Hi Florian, Ebay me old mate, slaters is the company name I think. Ebay is great for me living so rural, it's just the carriers that are bloody useless lol
The T piece continued. After the mid fixings were accurately spotted through, the T piece was unbolted and the cuts made using a 2mm angle grinder disc, leaving enough meat to create a strong joint.
Please note, I wouldn't recommend running the vehicle with the T piece support removed but when tightly nipped up I don't foresee any problems what so ever 8)
Now I'm thinking about the fuel tanks that fill the panniers voids down both sides, and the exhaust box inner louver panel.
So, easy enough to do and a big space available when it's done.
There's always a compromise and this job is no exception, it requires the mid deck protrusions to do just that but very necessary, a total of 8 m3,s needed to hold this section tight.( Reduced heads).
The pointy end fixing a compromise also to keep it strong and therefore in place, a total of 8 fixings required again but at different angles this time.
Reduced heads x4 each side will hold it tight.
The vertical reduced head fixings will be lowered into the angled brace so they are not so prominent, the gap between the brace and the T piece will be filled and a weld bead added.
A quick check with the turret in place and all is well with plenty of clearance taking into consideration the turret bustle underside louver vents.
A little shaping required at this end. Everything lines up beautifully when offered up, showing that the hull, hull sides and everything inbetween is very secure indeed.
Lots done, I think I'm now ready to paint the hull so I have started on the colour that I want to show through the top coats, the weathering coat of red lead I will also use mat black but that's for tomorrow.
More on all this paint and today's T piece work in a bit. 8)
As I said lots done, I think I'm ready to start the hull painting process, this needs doing now as she is getting very heavy indeed. I can then get the rubber ware installed. 8)
I will post pics of the T piece and the drivers hatch work tomorrow.
You have to think in reverse as all this will be under the top coats but will need to show through where I feel it looks convincing
I will also use matt black here and there.
I will maybe  use the hair spray technique and talk you guys through the process
All coiled up and hissing.
I'm not trying to cover the whole thing just a bit random so as we rub back it's all a mystery.
Final detailing for the deck, and the drivers hatch reduction. 8)
How to reduce the drivers hatch thickness but remember it is tapered!
This will make your elbows sore.
Dressing the T piece
A tip, don't throw away your broken power file belts as they are great for smoothing this kind of radius.
Milliput weld to the top fitting of the exhaust box completes the rear.
I think that's the last of the milliput for now.
The rubber sealing tube for the drivers hatch
Painting 8) how strong are those bazooka plate brackets?!
Light stone, the correct colour and from a military paint supplier too.
God this thing is big! I'm tempted to use a bigger spray gun but the air brush gives a nice finish.
Been liked: 1715 times
keep at it phil, marathon build, the forum are enjoying it, regards simon manning.
Thanks Simon, its an awful lot of work but a very pleasurable steep learning curve with a new kit relase. 8)
A few more pics of the bits I don't normally let you guys see.
Should look a bit like this one day
Appling the shading that sits under the top coat
Daniel Brooker
Been liked: 2 times
nice work Phil the priming/painting looks great :D
whats the process of getting that authentic rust finish on the tracks? 8)
Dan B
Hi Daniel, water! 8)
Has liked: 1033 times
Phil, well done, looking good and it’s great that you chose to sort out the thickness of the driver’s hatch. I’m going to sound like a broken record though and just say that a rust finish on the tracks looks anything but authentic for a Chieftain in service. Now I’ll shut up because I recognise that for many tank modelers simulating rust is in the moment as the woke would say. Each to his own.
