- Been liked: 2 times
Loving those fender lights nice addition can you recommend which lights you are using for all your lights and a good place to purchase them?
As ever in awe of this build
Dan
Dan
- Has liked: 2267 times
- Been liked: 7152 times
Hi Daniel, ebay, warm white 12v pre wired with mounts, (you may need a voltage converter dc/dc 12/24v step down module also found on ebay, very cheap. Your motion pack may have a 12v outlet) you chose the physical size, say 3 ,5 or 10mm dia .
I've cut the T piece out, more on that later. Oh and nothing moved absolutely nothing!
- Has liked: 294 times
- Been liked: 641 times
Another excelent work from you Phil,
where do you get the letters to glue on parts?!
Hi Florian, Ebay me old mate, slaters is the company name I think. Ebay is great for me living so rural, it's just the carriers that are bloody useless lol
The T piece continued. After the mid fixings were accurately spotted through, the T piece was unbolted and the cuts made using a 2mm angle grinder disc, leaving enough meat to create a strong joint.
Please note, I wouldn't recommend running the vehicle with the T piece support removed but when tightly nipped up I don't foresee any problems what so ever
Now I'm thinking about the fuel tanks that fill the panniers voids down both sides, and the exhaust box inner louver panel.
Lots done, I think I'm now ready to paint the hull so I have started on the colour that I want to show through the top coats, the weathering coat of red lead I will also use mat black but that's for tomorrow.
More on all this paint and today's T piece work in a bit.
As I said lots done, I think I'm ready to start the hull painting process, this needs doing now as she is getting very heavy indeed. I can then get the rubber ware installed.
I will post pics of the T piece and the drivers hatch work tomorrow.
Final detailing for the deck, and the drivers hatch reduction.
Painting how strong are those bazooka plate brackets?!
- Been liked: 1654 times
keep at it phil, marathon build, the forum are enjoying it, regards simon manning.
Thanks Simon, its an awful lot of work but a very pleasurable steep learning curve with a new kit relase.
A few more pics of the bits I don't normally let you guys see.
- Should look a bit like this one day
- FSMWB0416_Takom_Chieftain_08.jpg (93.72 KiB) Viewed 700 times
nice work Phil the priming/painting looks great
whats the process of getting that authentic rust finish on the tracks?
Dan B
Dan B
Hi Daniel, water!
- Has liked: 1024 times
- Been liked: 2094 times
Phil, well done, looking good and it’s great that you chose to sort out the thickness of the driver’s hatch. I’m going to sound like a broken record though and just say that a rust finish on the tracks looks anything but authentic for a Chieftain in service. Now I’ll shut up because I recognise that for many tank modelers simulating rust is in the moment as the woke would say. Each to his own.
