Mick's Grant
Forum for discussion relating to the M3 Lee nd Grant Medium Tank
michael hilton
Has liked: 1564 times
Been liked: 835 times
Re: Mick's Grant
Post by michael hilton »
Good afternoon, thank you for your replies Kian, Dennis and Adrian. I have ordered a Spektrum eight channel receiver. It is a genuine Spektrum from my usual model supplier.
Early in the M3 build I decided to change the 'recoil' from the sponson to the turret. I was not keen on the 'Special' so I purchased the standard recoil pack. The servo's are now installed and working. Moving on to the lights, I have the Turnigy dialed in, tech term. It's all looking good, most enjoyable kit to build, recommended by Mick. :)
michael hilton
Re: Mick's Grant
Good morning everyone, I spent this morning locating the upper hull and turret. There is always a glitch is there not....
I have to say all is well apart from this small issue.
I have the drive motors on my transmitter sticks, left and right, forward/reverse. When I move the right hand transmitter stick, the turret also turns.....Not supposed to do that....
Before I delve into the depths of the lower hull, is there a simple answer. The turret turn is on the right hand transmitter stick, left to right, and works fine on it's own.
I was careful not to move the transmitter stick both ways.... :roll:
Any thoughts before I remove the upper hull and turret....Mick
Has liked: 2267 times
Been liked: 7152 times
Re: Mick's Grant
Hi mick, looking good mate, may I suggest that you first check the mixing of the channels on your tx before you dig deep in the hull. 8)
Has liked: 1419 times
Been liked: 1594 times
Re: Mick's Grant
If you scroll the thumb wheel on the transmitter to the right, you should see a "Monitor" screen, with the various outputs displayed in a line.
When you move a control stick or activate a switch, you should see the relevant control move on the screen. You can do this without switching on the tank.
When you move each of the sticks, does only one output move, or do you get some moving together ?
If the latter, you have some form of mixing enabled on the transmitter, which will need to be disabled so that only one output changes for each control on the transmitter. If the former, it sounds like you have two channels linked somewhere in the wiring.
michael hilton
Re: Mick's Grant
Hello Adrian, ok, checked the Monitor screen....and yes both RAL and LAL move together, so the transmitter right hand stick is moving both controls. Not sure how to disable this mixing issue, I have looked at the Mixing screen which shows INH on all positions. I have a spare channel available on the left stick, left to right, I could try moving the receiver lead. I have never used 'mixing' with my models...Mick
Re: Mick's Grant
Try this, with the tank off:
Press the thumb wheel to get to the "Function List" screen.
Scroll the thumbwheel right down to "System Setup"
Press the thumbwheel to select.
Scroll the thumbwheel right to select Yes, and then press again to select.
Use the thumbwheel to scroll down to Aircraft Type and press again to select.
Use the thumbwheel to scroll down to Wing. You'll probably find it's on Elevon or Elevon-B.
Press the thumbwheel to select and then scroll so it says Normal.
Press the little Back button until the transmitter returns to the normal screen.
michael hilton
Re: Mick's Grant
Hello Adrian....eureka, followed your advice….all is well, Knowledge is all things, thank you, I will rest easy. :) Mick
michael hilton
Re: Mick's Grant
Good morning, ran the options this morning....every option working as expected. The Grant is a very pleasant build, a small sized model, easy to manoeuvre on the work bench, ideal for the smallest bedroom. Wheels to fit, tracks and paint....what more could a man ask.... :) Mick
Has liked: 129 times
Been liked: 772 times
Re: Mick's Grant
That's looking really good Mick! Glad you got everything hooked up and working! I agree the Lee/Grant is a unique looking model.
michael hilton
Re: Mick's Grant
Hello everyone, as you can see I have been very busy building the replica engine :roll: I wish.
Thank you for your comment Robert.
Reference the new modules, John, I returned the Audio Module to Armortek I had a problem with the 'sounds' programme. The main gun and M/G were tweaked, only needing Kian's gentle touch, those issues were resolved. The other difficulty centered around Motor Control B. This issue was identified by 'Adrian' who corrected the turret turn problem by pointing out that my Spektrum receiver was receiving two power inputs at the same time, not a good idea.
I disconnected one power supply by removing the 'red' lead from the three lead control cable going from Motor Control B to the Rx...hope that makes sense.
I have not had any problems with my main drive motors. All other 'options' work and operate as they should. I am currently configuring the battery wiring to exit through the rear engine compartment doors...I can disconnect both batteries and recharge each battery individually...it is not now necessary to remove the turret and upper hull to access the batteries....Mick
It's a bugger to start...
Re: Mick's Grant
Glad to hear you have things sorted, and I love the trompe l'oeil radial engine.
Now you just need a small bottle of used engine oil taped to the rear of the hull, with a pin hole in it so it leaves a dark puddle every time you park the model :lol: :lol: :lol:
Been liked: 1783 times
Re: Mick's Grant
Wonderful news Mick, I'm chuffed for you, and what a great idea with the engine bay enhancement 8) ,
Phil could learn some lessons here :lol:
michael hilton
Re: Mick's Grant
Morn'in all, finished the rewire...as before the batteries exit through the rear engine doors. Each battery can be isolated and charged individually.... Mick
Derek Attree
Has liked: 218 times
Been liked: 183 times
Re: Mick's Grant
Post by Derek Attree »
Hi Mick
Looking good like the engine idea better than looking at a golf trolly battery.
Frank Breitenbach
Has liked: 54 times
Been liked: 689 times
Re: Mick's Grant
Post by Frank Breitenbach »
Hi Mick
A really good idea with your engine photo. Very easy but very effective! I like it.
The lights inside your model looks also very nice!
Frank
