- Has liked: 2267 times
- Been liked: 7152 times
Lots done today like milliput welds, soldering the rear fenders, made the wading hooks and fitted them.
- Has liked: 775 times
- Been liked: 1743 times
Can you remind me what's this technique?my integral peg and hole technique
Hi Vince, it's the leg or peg that will hold the piece in place when it's not convenient or correct to use a bracket. The leg or peg which is either part of or is drilled into both the piece and the model, it is then tapped into an interference fit drilled hole and then bonded and finally finished with a milliput weld bead.
That all sounds like a legal statement
OK. I get it now. You modified the back of the wading hook to make one or two pegs.
A little more done. Does anyone know of a supplier of British/NATO single bulb light units suitable for our Chieftain's?
- Has liked: 13 times
- Been liked: 22 times
Hi Phil, your attention to details is outstanding and to say I am envious would be an understatement. I am enjoying following your build and your tips are going to be invaluable when I get to those areas. In preparation however I was wondering what size is the piano hinge? Andy
Thanks for the praise Andy, I will measure the 1/35 kit hinge and let you know the correct size but basically somewhere around the 10 to 12 mm open hinge would be very nice but it's what you can get hold of.I am now trying a new technique which hides the hinge flaps inside the bin, I then add a dummy flap to the outside, this being bonded in place, details to follow.
The detail I'm adding is really down to the owners spec, I could go even further but hes very happy with the level I am applying so I'm happy to! I really want to spend some time installing my high pressure smoker and improving the sound quality so this baby will be something special
Andy, after measuring the hinge on the small kit and transposing ( that's a good word) the total width of the open hinge would be no more than 14 mm. I doubt that the workshops contracted to build the bins had only one type of hinge so a little artistic licence can be used, so plus or minus a couple mm would not hurt.
- 68C85FA9-E0AA-45E1-A24A-C18EA194B173.jpeg (115.79 KiB) Viewed 1285 times
A bit more done over xmas.
More work to the rear fenders, to include the light brackets, fender bin frames, first aid box, number plate lamp and the lovely rear reflector.
- Has liked: 117 times
- Been liked: 256 times
Hi Phil
Really nice work on the extra details. The rear is definitely looking the part now - superb!
Thanks David, I bit more done today on the rear deck
- Charles A Stewart
- Has liked: 500 times
- Been liked: 913 times
Hi Phil
Great work with your project, must confess I took the dremel cutter to the studs then filed.
One learns so much by watching, many thanks for all tips.
Good new year
Charles
Good new year
Charles
Progress
The armoured fuel tank filler caps. Anyone have any photos of the caps open?
