Building my Limber
Alan McDade
Has liked: 14 times
Been liked: 6 times
Building my Limber
Post by Alan McDade »
Hi folks - new guy here building the 25 pounder and limber. So I thought I would start with the limber and have completed a dry build but noticed that the doors do not open fully. Anyone else have this issue and how did you go about fixing it?
The clash appears to be at the hinges not allowing the doors to open fully. They will only open to about 85 degrees whereas photos I have seen they appear to open more than even 90 degrees?
Advise appreciated.
Has liked: 1485 times
Been liked: 1695 times
Re: Building my Limber
Have a look here:
http://www.armortek.co.uk/Forum3b/viewt ... 74&p=44124
In it Dave says he had to re-profile the hinges to get the doors to open fully.
Alan McDade
Has liked: 14 times
Been liked: 6 times
Thanks,
I found the part about modifying the hinges. Confirms what I thought needed to be done.
Received Dave's Limber and 25 Pounder upgrade kits this morning.
Absolute class and the detail is superb. I am going to busy over the next few months.
Alan McDade
Has liked: 14 times
Been liked: 6 times
It's been a while since my last post but I have been busy and thought I would share some updates on my limber build.
Firstly I have 'dry' built the Limber all up and then took it all apart again and got to thinking about the possibility of having a full set of ammo trays and how would that look?
So I parked the build and went onto my CAD system to draw up some plans for the racks and when I was happy I had the parts laser cut out on 1.5mm brass.
The laser cut brass ready for assembly.
Assembled into the face plate
Side view of the assembly
Then it was back to the CAD system to draw up the Ammo Trays, which again I got them laser cut out of 1.5mm brass.
The Ammo tray parts.
The end parts needed to have 1/16" rivets fitted.
The assembled (dry) trays look well in my opinion.
Assembly underway
Assembly underway
And finally this is as far as I have got.
All trays dry built.
So I am now waiting on some more parts to complete the Ammo trays and will continue the story in due course.
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Beautiful work!!!!!!
Dave
www.armorpax.net
Marcus Kwa
Been liked: 39 times
Post by Marcus Kwa »
Wowww, amazing!! :shock:
Where can I order some?
Marcus
Has liked: 161 times
Been liked: 831 times
Alan
Beautiful brass parts, I'm sure many would love to have a set of those racks and bins. They really add a lot to the limber. Nice work!
Has liked: 2282 times
Been liked: 7196 times
You put us to shame Alan! Beautiful. 8)
Has liked: 792 times
Much better than that. Amazing.
How do you intend to assemble them. Glue or solder?
Robert Reid
Has liked: 99 times
Been liked: 446 times
Post by Robert Reid »
Wow!!! That is impressive design and execution!!!
RPR
Alan McDade
Has liked: 14 times
Been liked: 6 times
Vince Cutajar wrote:
Fri Dec 27, 2019 7:51 pm
Vince - intent is to solder them but there might be a mix of both. I will see when I get to that stage.
Alan McDade
Has liked: 14 times
Been liked: 6 times
Marcus Kwa wrote:
Fri Dec 27, 2019 6:43 pm
Marcus
Marcus, I have modified the design on my CAD system and the updated design has not been sent to the Laser cutting man yet. The change was because of some photo's I found which gave more detail of the cage structure. I will share more when I have completed the mods to those in the pictures.
