Has liked: 2267 times
Been liked: 7152 times
Interesting day, I think I've cracked the non slip surface coating conundrum, and although I was not planning to start on the bazooka plates.....I have! The front plate front bracket is in the wrong place. All the plate brackets will be removed, new ones made and soldered in place with an overlap to look more like the 1/1.
The visible m3 fixings on this build will all be replaced with very much smaller fixings where ever possible. 8)
The plates need to look and hang like this. Ignore the m3 lower fixings as the brackets they are holding will be soldered in place.
You can use the score and snap technique if you wish.
You will need to bolt to the fender brace here. You will also need to make a new shorter bracket.
It doesn't line up like the 1/1 so it must change.
Been further counter sinking the counter sinks.
It gets better with the more coats you apply.
Well I like it.
Well I like it.
Nice new motor plugs.
Richard Goodwin
Has liked: 294 times
Been liked: 291 times
Post by Richard Goodwin »
Phil, you may find that the first tie down from the front on the bottom row of tie downs shouldn't be there unless of course you have a picture that says otherwise. My urban camo pics show nothing there!
Thanks Richard I will take a look. Getting on with making the new brackets and the soldering of the lower ones.
Soldering is tricky but once you have the knack your away, I wouldn't recommend silver solder as you will buckle the plate with the higher heat involved.
Getting on with the new bazooka plate brackets.
Shown before, the method of holding the m2 screws to form a rivet head using a grinding wheel.
A tip, use the grease to hold the gearbox shaft bush in place, I managed to slot it all together first time but be careful not to drop the bush in the final drive casing.
Don't really need to say use heat shrink do i?
A tip, just go over the crimps again just to be sure as the lower connections will be out of sight very soon.
Nice new plugs on the motor leads.
Richard Goodwin
Phil, since your using grease, is there any need to use a liquid gasket on the mating surfaces to seal it all in?
Use the grease for the gasket as the mating surfaces are very good indeed, the internal grease is very viscous so it won't migrate. 8)
Been liked: 1796 times
Richard's right about the holes, I've not seen that pair at the front on any bazooka plate in my library unless there bullet holes :D
Been liked: 3498 times
"A tip, use the grease to hold the gearbox shaft bush in place, I managed to slot it all together first time but be careful not to drop the bush in the final drive casing."
CG0704 should be loctited in place into ES0243.
The grease only holds it whilst it is slotted into position. 8) A good day spent on the bazooka plates.
Nice little kit bin catches, armortek have made a good job of those.
The plates almost done on this side now
I do like these kit latches.
The unwanted holes filled with rivets and then rubbed back flush.
Filling the unwanted holes with rivets.
A tip, use a blade to remove the solder as a file will clog and scratch the work.
Today I have been making new bazooka brackets that attach in a more correct way over the fender/hull fillet, also installed the hull/fender fillet and some more stiffning strips the entire length of the fender, all hard to see but it is tbere. 8)
I have tried to keep the bazooka plates nice and evenly hung but after lots of research it seems the plates were far from straight and true.
I need to add the centre gusset to the bracket, then add the other bracket details that I have no idea what they are for.
The bolt detail for The fillet to add of which there are many but I need to finish the brackets beforehand so the bolts are equidistant between them.
The other brackets which are to fix the fenders to the hull, these are a little fiddly to make but do look the part.I have used 2mm rivets for the fillet strip as the bolts would have been tiny.
Now onto the rear bin. 8)
Working on the other side of the vehicle now.
Fashioning the bazooka plate hanging slots using needle  files.
I'm using ali u channel for the fender/bazooka plate brackets.
It's a messy business soldering, well it is when I do it!
But they do clean up nicely.also been filling the counter sinks. The rear side bin will cover most of this area but it still needs doing.
I have made new tie down loops from copper rivets as the kit loops just won't take the solder.
Long rear bins having the folded joints soldered.
The rear binz , well one of them. 8) I did try riveting the hinge once more but the hinge just gets knocked out of line everytime, your better off bolting or using threaded rivets so you can get those shut lines right. 8)
To attach the hinges this way you have to trim 1.5 mm from each of the lids inside edges.
The off side nearly complete, now do I add the wading hooks? 8)
I think the hooks are for a wading attachment.
I shall leave the m3 nuts securing the bolts for the long bin until final fitting of the long bin, or I may use half nuts and leave them in place.
If you go down this route drill the fillet detail fixings deep into the upper hull for a strong bond.
Has liked: 775 times
Been liked: 1743 times
Enjoying your out-of-the-box solutions.
Thanks vince, and many many thanks to Gill and Mark for all the help over the years, God bless you Gill. Kian and Monique you have much to live up to but I think you are doing just fine!
Today I have been making small parts as in the wire ropes brackets, not my favorite pass time but very necessary indeed.
Here's a tip, you can easily permanently darken the wire ropes by simply blueing with a blow torch, you can also use the blow torch to mould the rope to lay the way you want it on the vehicle, we all know that these ropes have a mind of their own!
Nice towing eyes these, very much like real thing.
There's some cleaning up of parts before assembly.
Not my favourite job making the small parts but has to be done.
