I think this is very good advice for axles, spindles, shafts, bushes, pivots and any moving metal to metal surface parts, if anyone is going to leave their gearboxes open to the elements.Armortek wrote: ↑Tue Nov 05, 2019 5:17 pmStill very much our advice.Stephen White wrote: ↑Mon Nov 04, 2019 6:29 pm......... I do use moly inside the gearbox and on the axle spindles but avoid wet lubricants like the plague. This has been longstanding advice from Armortek although I don't believe it's been re-validated recently.
Unless you have a sealed environment, over time contaminants will mix with the wet lubricant and in-effect act as grinding paste.
Kian
With the proviso to, strip clean and lubricate on a properly managed maintenance program dependent on use and time.
In my daily working environment, I support and maintain over a couple hundred motor and gearboxes, the majority are oil filled and a few are grease filled. All are sealed and to a certain extent sealed for life.
We only use quality lubricants namely Kluber lubricants. Though before Kluber became our universal supplier, we used many high quality Rocol products.
I cannot say I have ever used or come across Dry Moly lubrication sprays or dry Graphite as the primary gearbox lubricant.
That's not to say there are not any out there though.
I do consider the "Rub" effect on the gear teeth, it could over time remove the dry lubricant, leaving areas of metal to metal. Unlike cams, slides and plain bearings that can be coated, Gear teeth are constantly meshing with different surfaces, wet lubricants reduce transmission shock, reduce temperature and when kept clean, provide constant renewable lubrication between the gear teeth.
So I'll be sealing my gearboxes, and will use a semi fluid grease, designed for longevity and low gearbox maintenance
The rules of great gearbox maintenance, Quality parts, perfect alignment, cleanliness and quality lubricants. oh and no leaks.
Dragged this off the net for the open gearbox builders
Rocol Dry Moly Spray
Description
High purity, extreme load dry film molybdenum disulphide spray designed for use where a wet lubricant cannot be tolerated. Applied wet for great penetration, becoming touch dry within 2 - 3 minutes, leaving a dry protective film containing more than 70% molybdenum disulphide. Dry Moly Spray is an assembly lubricant for sliding surfaces such as plain bearings, pins, cams and slides intended to reduce friction and therefore increase life of moving parts in highly corrosive environments.
FEATURES AND BENEFITS:
Prevents galling, pick-up and seizure
Resistant to high loads (up to 7,000 kg/cm2)
Excellent wear resistance
Fast drying, over 70% molybdenum disulphide content once dry
Ideal for applications where a totally dry film lubricant is required
Temperature range -50ºC to +450ºC
