Has liked: 2267 times
Been liked: 7152 times
A little tease from tomorrows coming post.
I think that's it for the detail on the road wheels, lock nuts in place, I don't have any more of those until delivery tomorrow. When you think that it's just 20 bolts and nuts per road wheel assembly that will carry all that weight, and all the directional forces involved, the nut either needs lock tight or a lock nut, the latter being the choice of the chieftain designers!
My bible at present.
Very nice castings, it all goes together beautifully will a little fetling.
Awaiting the m3 fixing order.
Charles A Stewart
Has liked: 500 times
Been liked: 913 times
Post by Charles A Stewart »
Hello Phil
Hope you don't mind my asking, I have No34. I have been putting the the larger parts together to save space. I am working on the running gear and have found the hub caps do not just screw in nicely.
After some work i have sorted the idlers. Being aluminium don't wish wreck such an investment. Could you please advise on this issue, yours seem to fit perfectly and I like the inspection fittings. I will now be raiding my outdoor gear repair box.
Many thanks for a very useful stream.
Charles
Hi Charles, you need to run the ali idler threads over a rotary wire brush if you have one to polish and deburr, failing that use a hand wire brush then a little oil on the thread and all should be fine. Ali threads "pick up" and bind terribly if they are at all tight, it's easy to clean up the male thread but more difficult to clean up the female. Hope this helps if not let me know. 8)
andymusgrove
Has liked: 192 times
Been liked: 89 times
Post by andymusgrove »
Morning Phil
Another great build blog thank you very much.
Can I ask what reference material you using for your bible please. I like the drawings you have there.
Keep up the good work.
Andy
Hi Andy, I will check which book/books I am using for reference later, for now photos from Tuesdays exploits 8)
About 2 days work in my "day box" selected parts container. There are still many more parts to be picked for the shock absorbers assemblies.
I'm using quality Tamiya grease for the bushings.
Nice warm sunny day yesterday so the etch primmer could be applied outside.
I decided to nip up the 8mm nuts to hold the big arms in place while I work on the assembly, these nuts can be loosened later or the suspension won't function.
The problem area that will take some head scratching to solve, it's by no means necessary to change the geometry of the belly plate angles and the rear plate lower edge, unless you want a very accurate chieftain example indeed.
A tip, best keep the paint out of this area or the return roller mount will just not go in to it's seat.
Richard Goodwin
Has liked: 294 times
Been liked: 291 times
Post by Richard Goodwin »
Like the detail in the road wheels Phil, looking very good. Now you've used lock nuts, did you use the same length hex head bolts as the original cap head bolts?
Hi Richard, the kit size standard cap head length will be slightly to small, so you would need to use longer bolts ( technically they are screws as they are all threads) and cut to size, best carefully measure the length that you require as some lock nuts may vary in length. If you study photos of the 1/1 wheels the bolts protrude ever so slightly past the nuts as they should, so factor that in. 8)
The first pair of road wheels have the shock absorbers are all but finished, and four more to complete today. Looking very closely at the reference photos of the wheel hub, there is just one more tiny hole to detail which I shall machine today. 8)
There's quite a lot of work involved to clean up these machined parts but well worth the end result.
A few hours of filing here.
The reference book with the nice line drawing in it, I still think that the Haynes manual has some of the best info and photos.
Excellent and detailed kit this one, if anyone wants it in around 4 months time give me a shout.
The 1/35 example for reference. I will sell this little kit on when I have finished referring to all the detail.
I'm not going to lock tight the axles until a lot later.
Lovely well made quality feel to these big buggers.
My God I have done it, I've corrected the rear belly plate and the rear plate, it is a compromise and it's not for the fainthearted! More details tomorrow. 8)
Hows that Stephen?
Hows that Stephen?
The rear plate to belly plate intersection is now perfectly straight and square!
Ivano This one is for you to copy. this is the improved motor not the crappy early example.
Charles A Stewart
Cheers Phil
Your advice has worked nicely so far, re sorted idlers hubs and starting the road wheel hubs next. Track bashing presently. Given I am new to these models & thus fainthearted, I like what you have done to the back of the hull, but I will just watch for now. If you don't mine may I copy your idea of replacing those bolts underneath?
Steve Norris
Has liked: 8 times
Been liked: 697 times
Post by Steve Norris »
Hi Phil
A top job your doing as usual, Do you have the dimensions for the rear plate/belly plate mod you have done. No point in re-inventing the wheel if I don’t have to.
Thanks Charles and you carry on don't mind me it's all for the common good!
Steve are you referring to the the whole mod as in the rear angle adjustment or the access plates dimentions?
Ivano Costantini
Been liked: 735 times
Post by Ivano Costantini »
Hi Phil,
it will not be easy!
Just a curiosity: the tank model does not open this way,
only the doors can be opened.
Thanks Ivano
Been liked: 1793 times
i have to agree with Ivano, unless your going to make structure changes to the model deck, it will be impossible to remove the dummy motor/gearbox.
Coming back to the idea of a light weight possible Vac formed "dress up" cap over the model motors.
Unless it's going to be a static mode? :cry:
Now if you were to build a ARRV, that's a different "kettle of fish".
Like the extra holes in the road wheels, did you make a jig template?
I may cut the deck out on ours so this can be done but you are correct only the hatches open, the photo is for your engine position reference only. 8)
More photos from yesterday. Has any one assembled the suspension units yet, if so please email me!
As close as your going to get using this method and nothing removed but for a slither from the rear plate bottom edge, this gap is then filled with the belly plate cut sections as they are folded to meet the rear plate.
The paint has arrived.
The bump stops need cleaning up.
The road wheel fixings have arrived.
What you need to cut into but only part way through and then fold. I shall also cut a slot down the entire hull centre line for the weld bead to sit in, and yes the hull belly plate was welded together from two separate plates!
After cutting the bottom of the rear plate you will need to get it flat and square, remember the weld bead could do with a slot to sit in, "non butt welds"
Last edited by Phil Woollard on Fri Oct 25, 2019 12:47 pm, edited 2 times in total.
