Sdkfz 7 Build
David Brady
Has liked: 187 times
Been liked: 711 times
Re: Sdkfz 7 Build
Post by David Brady »
Hi,
A little more progress, I've been putting off trying this for a while as it's a little tricky.
1/8 half round beading before straightening
Once straightened I manipulated into shape and soldered on
Handles soldered on x 5
Should be a little easier on the other side ..I'm happy with the result
Now for some meditation before I attempt the other side
Has liked: 2267 times
Been liked: 7152 times
Re: Sdkfz 7 Build
That's about as tricky as it gets David, nice detail. 8)
David Brady
Re: Sdkfz 7 Build
Your not wrong Phil...anyway time to fit Steve Winstone front tow hitch with starter pins, made from steel it's a great addition to my halftrack. Many thanks Steve, I know you had fun making it.
Fits like a glove
Fits like a glove
Reference picture
Reference picture
David Brady
Re: Sdkfz 7 Build
Wheel bolt configuration changed to resemble the real vehicle
Original
Original
Modified
Modified
Been liked: 1644 times
Re: Sdkfz 7 Build
Dave, Nice add on extra, keep at it, regards simon.
Robert Reid
Has liked: 99 times
Been liked: 446 times
Re: Sdkfz 7 Build
Post by Robert Reid »
David Brady wrote:
Tue Sep 17, 2019 8:27 pm
Very interesting bolt pattern... what's the engineering idea behind this? The asymmetric pattern has obvious applications in something like a gear train or a wheel/dolly that has to have a very specific balance. But wondering why the Germans would have used such an odd pattern for what is, in essence, a dolly wheel?
Beautiful workmanship on the whole build! And definitely interested in the engineering behind this.
RPR
David Brady
Re: Sdkfz 7 Build
Thanks for the comments. The hub was flat on one side ...maybe clearance/balancing issue.
David Brady
Re: Sdkfz 7 Build
Had around 5 hours to play on my sdkfz7 today so I decided to tackle the front and rear ribs on the bonnet but as usual I misjudged the task, after about three attempts I managed to get one of the ribs sodered. I used 1/16 half round beading. The problem is its got a mind of it's own when you heat it up!
Fabian Bekkers
Has liked: 190 times
Been liked: 119 times
Re: Sdkfz 7 Build
Post by Fabian Bekkers »
David Brady wrote:
Sat Sep 21, 2019 6:53 pm
Very Nice David beautiful details I start on mine when I have finished the kingtiger.
My sdkfz7 was partly built so it would be quite a challenge
Huzaren prins Alexander 🫡
David Brady
Re: Sdkfz 7 Build
Thanks Fabian, front rib added and reference picture used below.
Reference picture
Reference picture
David Brady
Re: Sdkfz 7 Build
Hi,
Opened up the slots around the sprockets, this was a case of pushing through a small amount of metal to finish.
David Brady
Re: Sdkfz 7 Build
Hi,
Not to much to report on the sdkfz 7 front except some nice quality upgrade parts supplied by Michal Matata
Re: Sdkfz 7 Build
They are a work of art Dave, lucky to have these craftsmen around, imagine making them, very difficult and time consuming, worth every penny if you enjoy your vehicles, regards simon, p.s. lets see some more building, i am into these 7s at the moment.
David Brady
Re: Sdkfz 7 Build
Your not wrong...I'm trying to resist ordering Michal's front rim and tyre upgrades ...... don't know how much longer I can hold off!
I've got stuck opening up the holes in the wheels but will get back on it soon.
David Brady
Re: Sdkfz 7 Build
Hi,
Three wheels and tyres ordered ....something to look forward to!
