- Has liked: 187 times
- Been liked: 711 times
Looking good phil...I like the patch on the rear bin
- Has liked: 2267 times
- Been liked: 7152 times
Some white wash examples. Which one to choose, well lets see how in evolves....my favourite part of the process, that way no two are ever the same.
- IMG_3311.jpg (115.07 KiB) Viewed 2458 times
- dscn5367.jpg (221.16 KiB) Viewed 2458 times
- tigre_jose_gallery06.jpg (61.42 KiB) Viewed 2458 times
Some more of yesterdays antic's. Maybe boring photos for some but they are to show how the colours are built up, also using different edits to play with the light, hue and shade.
I wonder if Armortek would produce a limited run of track segments for us that are more detailed, ie the track horn is cut out for example, I bet there is a market for them, just to hang on the Tigers, not for functioning tracks as they would break.
I am happy with this level of white wash and weathering and will go for it tomorrow, unless otherwise directed ? More photos tomorrow morning of my new milliput colour choice and removable plate welds technique.
The welds and contrast shading. Right better get my white wash bucket and brush out then.
- Has liked: 775 times
- Been liked: 1741 times
When you applied the milliput for the turret roof, what did you do so that the milliput does not adhere to the turret roof? Masking tape or maybe kitchen aluminium foil?
- Been liked: 10 times
Where did you get the rivets and how do you attach the main deck as I cant see any screws? The shading for the drive sprockets what colour did you use?
Loving the advice and build.
Allan
Allan
A little tease for tomorrows post.
Vince I use oil on the part you want to release, just to make sure run a very thin blade along the joint to further separate. This technique is one of the hardest to get right.
Allan, I am using some of the stock deck fixings but only 4 total, you just can't hide them just make them less prominent. The shading around the sprockets is just a shade of black or a dark brown that I mix up, try mixing green and red in different ratios to get that sprockets shading colour, buff is also used just depends on the environment you are depicting. The rivets are mostly from eBay Phil also found a supplier that has the smaller variety, I expect that he will post that info when he sees this post.
- Brian Ostlind
- Has liked: 971 times
- Been liked: 2066 times
Allan,Allan Shannon wrote: ↑Thu Sep 12, 2019 2:31 pmPhil
Allan
We sourced the rivets from two places.
Westfield Fasteners in Aylesbury
www.westfieldfastners.co.uk
and
EKP Supplies in Barnstaple
www.ekpsupplies.com
We now have one of the new sound modules so that will be going in along with the new speakers today.
The weathering will go on right up until Phil picks the ol girl up, I have chipping, scratches, shading, rubbing back, washes, rust and the environment, ie mud, dust water stains to add.
Jobs still to do are, turret interior (full). Cupola interior/exterior detail kit to fit, mg interior detail (hull, cupola and coax). Turret basket/floor with ammo storage and Armorpax batteries under the hull floor, Track painting (spare and chains) Running trials (with video). Interior light for the turret, and a lot more that I just cant think of right now!
- Been liked: 299 times
Hi Phil
Very nice work, thanks for sharing, I have a few spare steel track links if you are interested, no need to paint them just leave them in the mud for a few days.
Liam
Liam
Many thanks Liam PM sent.
- Been liked: 592 times
Hello Phil,
Weathering looks amazing, can you explain how do you apply
the white wash.
Best regards Yves
the white wash.
Best regards Yves
