Elektrikery
- Has liked: 7 times
- Been liked: 46 times
Elektrikery
Not really what I’m good at! I have the older set up from 2010/11, but one of the newer motion control modules. Can I use that with the one/some of the (amplifier) older modules? What radio transmitter would you recommend? Thanks in advance!
- Has liked: 1024 times
- Been liked: 2094 times
Re: Elektrikery
Simon, I believe the modules are backwards compatible but check with Armortek. Re radio systems, see the Knowledge Base here:
http://www.armortek.co.uk/Forum3b/viewt ... 8e522c9e45
Re: Elektrikery
Hi Stephen,
Thanks for the link. I had checked the knowledge base but saw it was more than three years old, I didn’t know if things had moved on significantly since then?
Simon
Simon
Re: Elektrikery
Simon, you're right, it does need updating. I don't think much has changed to alter the advice but I suppose it should be updated to take account of any changes which are relevant to the new motion system which Kian announced recently. I added one very minor change to the other topic on setting up Spektrum systems, to reflect on the update to the methods of binding Tx to Rx.
The most significant development on the radio system side is the advent of software defined radios, particularly those using OpenTX. Systems such as the Taranis X9D + offer a huge increase in capability. Liam Mahoney has, for example, used the system to simulate gear changes on his Tiger and the ability to use software defined virtual switches opens up more options for controlling the sound cards. I've got a Taranis and I'm relying heavily on YouTube Channels such as Painless360 and Joshua Bardwell to guide me through the software, which is pretty complex. Therein lies the issue. Software defined radios aren't for anyone not prepared to invest a lot of time and effort to master the programming. It's like learning any new software, or learning a language. It seems impossibly complex, confusing and impenetrable at first but once you get stuck in, there is a tipping point after which it all becomes much easier.
I'd say at the moment that the most popular radio system for Armortek models is the Spectrum DX range. Futaba were the default choice but their quality has fallen off significantly and development lags behind the other manufacturers. There are also known compatibility issues with the Futaba T-FHSS systems ie those capable of telemetry.
Re: Elektrikery
Thanks again Stephen,
Good advice/info. I’m not really interested enough at this stage to go the programming route. Reading again through different threads, it seems the Spectrum DX8 is pretty popular, so I’ll probably go with that, even though it seems to have been around for ten years or so!
Simon
Simon
- Has liked: 1419 times
- Been liked: 1594 times
Re: Elektrikery
Spektrum seem to upgrade their radios without changing the name, but look for a Gen2 or G2 transmitter (currently).
Re: Elektrikery
Dear All. Bench testing: everything works, except the main drive motors don’t respond. I’ve plugged them all different ways and no luck. I’ve and tried them direct to battery and they turn, so motors are ok. Any thoughts? Cheers!
- Has liked: 218 times
- Been liked: 183 times
Re: Elektrikery
Hi Simon
Check the spade connectors the motor wires plug on too are soldered in the board correctly.
On more than one occasion I have had dry joints where the pins are through the board.
Regard
Regard
Re: Elektrikery
Do the LEDs change brightness when you move the sticks ?
It looks like you have the older style connection cables. Which way round have you got them in the receiver ?
Earth - Armortek = Green Futaba = Black JR/Spektrum = Brown
Power - Armortek = Red Futaba = Red JR/Spektrum = Red
Signal - Armortek = Blue Futaba = White JR/Spektrum = Orange
There should be a diagram on the receiver to show which way round the plugs go in.
Re: Elektrikery
Thanks Derek, that’s interesting, I’ll check that tomorrow! Odd that both motor connections would be dry though!?
Hi Adrian, yes brightness changes. I have two identical setups, the other works faultlessly.
Re: Elektrikery
Does the relay click when you move the sticks ?
Does it behave the same as the working one ?
Adrian
Adrian
Re: Elektrikery
Yes, relay clicks. The sound, gun elevation turret rotation motors work same as the other one.
Re: Elektrikery
I notice one of the RH drivers is missing it's nut, and is sitting away from the heatsink, which may have resulted in it suffering heat damage.
Or the loose nut may have shorted something on the PCB.
I've repaired a few of these but I don't think I've ever had one which was dead on both sides.
Re: Elektrikery
Adrian, thank you, very observant! Nut replaced. These units were all originally plugged together by Armortek at my request. Not sure if they were ever test run. I’ve not had it switched on long enough to build up any kind of heat. As for the nut shorting something, I can’t say for sure. How would I check it? Thanks again.
