Has liked: 2267 times
Been liked: 7152 times
Lots more done, I tend to work on many things at the same time, this way paint can be drying while I fettle, fit and assemble other pars.
Drilling the muzzle break out to 16mm to accept the rifling insert.
Very nicely made addition, although out of focus.
Milling the loaders view port armour to accept the periscope.
Filing the rear angle of the cupola periscope covers.
I like the look of the full periscope rather than the later smaller version.
The correct hole milled in the turret roof for the periscope to fit right through and NOT just cut in half!
We are waiting for the escape hatch interior upgrade parts to arrive.
Just a little fettling to get a good fit, the hinge needs to be tight or it will drive you crazy as it falls open just when you don't want it to! The cap heads will be covered by the zimmerit.
Phil Dawe
Has liked: 755 times
Been liked: 298 times
Post by Phil Dawe »
Phil,
It just gets better and better! I cant wait for the FOA turret interior detailing parts to arrive :D :D
I found this photo of a late panzer ( :? ) turret interior showing the full size periscope in place, So I'm happy. 8)
Last edited by Phil Woollard on Mon Sep 02, 2019 8:26 am, edited 2 times in total.
mark lawson
Has liked: 2508 times
Been liked: 443 times
Post by mark lawson »
Phil, that's the inside of a Panther command tank its not a Tiger
RAG Militärmodellbau
IG Militärmodellbau
Close though init Mark lol. Mark would you have a nice pic of the internal breech lock that hangs from the roof by any chance, I have this line drawing below but could do with a decent photo so I can fabricate one?
mark lawson
I have a disk full of pictures of the Saumur Tiger I will have a look this evening their may be a picture.
IG Militärmodellbau
Much appreciated Mark!
mark lawson
This is what I have found on my Saumur disc, Kent may have more.
IG Militärmodellbau
Thanks Mark that's just the ticket, I think Kent has some competition!
Some more progress on the turret.
I have turned a new cupola hatch pivot post, we are still waiting on the cupola interior details to arrive.
Weld detail to the gun tube mount.
Weld details to the exterior of the turret roof. You can now see why I had to add the base plate to the ventilator.
Prepping the elevation/depression parts ready for assembly. I need to mount it all and get it functioning before the turret interior arrives, then find a way to hide it behind the 88 mm breech. It may not be possible!
Turret roof interior weld details begin.
Machining the mantlet pivot mount to reduce the 6 mm gap. Not entirely sure this will work but its a start, removing the front portion of the pivot mount will bring the mantlet back without causing any knock on effects, it will of course reduce the forward weight of the pivot.<br />I may need to remove more material but am being cautious as I go.
Has liked: 775 times
Been liked: 1741 times
That's a big milling machine you have there Phil. Looks like a Bridgeport clone. Will be interested to see the end result.
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Phil Woollard wrote:
Mon Sep 02, 2019 7:56 am
:D
Found an interesting Henchel factory drawing at Panzerbasics from the Per Sonnervik collection that might be of interest regarding the mantle/hatch issue. It looks as there was a bit of problem in 1:1 or at least on VK45.01 but I dont think it was any changes here later in the Tiger1 production.
It´s all in the details!
Thanks Kent, that drawing seems to show a 1.1 interference/protrusion over the hatches, now that along with the large mantlet gap and we have a bigger interference issue.
Hi Vince, yes that a serious bit of kit as far as modeling goes! I have had to ask a local engineering company to do the work as it need to be right.
I have just assembled the unit and I think it looks ok, any tighter and the pivot angles on the turret may be a problem. That's just 3.5 mm removed, care being taken as the pivot mount was 12 thou thicker at one end before we started, so around 4 mm in total . I will post photos tomorrow. 8)
The turret.
The nice rifling insert slipped in place
Real of Fake ?
Real of Fake ?
The new gap, acceptable clearance?
The hatches can now be opened when the turret is at 12 o'clock
I do have the hatch hinges slightly loose, two reasons for that, number 1, it helps with clearance and number 2, you don't break the hinges off.
Now you could also remove 4 mm from the back of the mantlet but you may spoil the profile so it's up to you.
I.m hoping to get the 88 breech to sit along side the elevation mech.
thumbs up.jpg (13.7 KiB) Viewed 2139 times
That looks so much better with the reduced gap.
Also love how the rifling insert looks.
Guess what I have been so quiet about? 8)
Lots of cleaning up to do now.
I tend to knock the pokey out bits off once its nice and hard, then rub the rest away with emery paper until I'm happy with it, I will also use milliput for any areas that prove to be difficult , like around the vision ports.
