Panther A barrel elevation
yves mouton
Been liked: 603 times
Post by yves mouton »
Hello,
The elevation of the barrel down works ok,
but the barrel elevation up does not work without a little help.
So my question is: do i have to make a counter weight the help the motor
put the barrel up?
Best regards Yves
Has liked: 1421 times
Been liked: 1603 times
Re: Panther A barrel elevation
I've seen this in the past when the current limiting resistor in the elevation motor supply is too sensitive.
Counter-weighting the barrel should reduce the load on the motor and allow it to operate correctly.
yves mouton
Thanks Adrian
Best regards Yves
