Tiger build
mark j. radick
Has liked: 393 times
Been liked: 538 times
Re: Tiger build
Post by mark j. radick »
Before ...
Last edited by mark j. radick on Tue Jul 02, 2019 10:04 pm, edited 1 time in total.
mark j. radick
Re: Tiger build
After...if you look closely you can see the flush rivet...if you tilt your computer screen back a bit ...the flush rivet becomes more apparent !
Last edited by mark j. radick on Sat Mar 19, 2022 1:13 am, edited 1 time in total.
Brian Ostlind
Has liked: 972 times
Been liked: 2068 times
Re: Tiger build
Post by Brian Ostlind »
You are taking it to to a whole new level Mark!
mark j. radick
Re: Tiger build
Brian Ostlind wrote:
Wed Jul 03, 2019 3:40 am
Thanks Brian.. I've been following your build for a while now ..Great work ! great seeing your tiger running !
Has liked: 134 times
Been liked: 789 times
Re: Tiger build
Beautiful work on your Tiger! I think the rust on the rear exhaust housing looks perfect!
Any reason not to use a lazy susan bearing for the turret though? I find they rotate much better than the brass rings. Personal preference I suppose.
Super work - thanks for sharing!
mark j. radick
Re: Tiger build
Robert E Morey wrote:
Wed Jul 03, 2019 4:45 pm
Thank you Bob....I guess it is just a matter of aesthetics...I would love to build a tiger in stainless steel and brass and leave unpainted
mark j. radick
Re: Tiger build
Had a hour or so to kill so I knocked out drivers vent and installed it...I'm always amazed how the colors can change with the paint depending on the light !
mark j. radick
Re: Tiger build
Been adding details to deck...once painted I will add periscopes to hatches
mark j. radick
Re: Tiger build
I decided to make my own functional tow cables... I do like the late Mike Stannard's tow cables but the white metal casting renders them useless for towing.... ...having made my own I have Mikes tow cables to give away for free...just pay shipping..I'm in SW Florida...I weathered the cables with the stainless steel blackener....so happy with results
Last edited by mark j. radick on Sat Jul 13, 2019 2:26 pm, edited 1 time in total.
mark j. radick
Re: Tiger build
How I cut hard to cut cable...I silver solder then cut with Dremel...only takes a few minutes and works great ! and no fraying
Last edited by mark j. radick on Mon Jul 15, 2019 1:49 am, edited 1 time in total.
Tim Carr
Has liked: 2281 times
Been liked: 95 times
Re: Tiger build
Post by Tim Carr »
If those cables are available, I would love to get them. I'm in the Tampa Bay, Fla area. I'll pm you for details.
Later Tim
Tampa Bay, Fla area USA.
mark j. radick
Re: Tiger build
Tim Carr wrote:
Sat Jul 13, 2019 3:27 am
Later Tim
They're yours Tim..I just have the cables as i'm using the mounting brackets..
Re: Tiger build
hi Mark
Your cables look awesome! How do you get the cable bent around the tear drop sheave so tightly? And then stuffed into the round ferule? Are your ferules crimped so they can withstand the pull loading? Fantastic work on all the details. Really a superb build.
mark j. radick
Re: Tiger build
Tue Jul 16, 2019 3:41 am
hi Mark
Hi Bob ...1st I turn then slide the ferrule on to the cable then I simply "tack weld" the cable to the thimble and to itself using medium strength silver braze I then slide the ferrule up tight to the pre tacked loop and silver braze the cable within the ferrule using a high strength silver braze...it is more than strong enough for my needs
Tim Carr
Re: Tiger build
Post by Tim Carr »
Received cables. THANKS Mark.
Later Tim
