Has liked: 2267 times
Been liked: 7152 times
I shall be starting a Late Tiger1 build within days, it should be interesting as it has just a few :roll: very nice upgrades ( note the Maybach engine kit box )....watch this space!
We are also waiting for other parts which include the engine radiators, those beautiful working fan units and the various fire wall vents and fittings.
The ugly git in the background has to turn all these boxes into something beautiful and I love it!
Has liked: 777 times
Been liked: 1745 times
Nice. Pulled up my deckchair, umbrella and popcorn.
Is this a 2017 Armortek model?
Steve Norris
Has liked: 8 times
Been liked: 697 times
Post by Steve Norris »
Hi Phil
Looking forward to this build,
I have a late Tiger 1 waiting for a rebuild and have been slowly gathering parts over the last year or so.
Like you I intend to fit a engine bay and fans plus lots of other aftermarket parts. I have one of Ivano,s Maybach HL230,s and a load of Steve Winstone parts plus turret ring armour and engine vent screens from Mike Stannard. Mark Lawson (Rivetcounter) has also supplied very nice c-shackles,tow hooks, mg mount and hatch hinges.
Just got a King Tiger to finish and I may make a start.
Thanks Vince, and yes it's the very latest model of the model. 8)
Thanks Steve, they do make a nice model. We also have Ivano's engine and a USB stick of build instructions. 8)
Steve Norris
Has liked: 8 times
Are you planning on using resin fan housings from East coast armoury?
I was thinking of using 4 x 24v cooling fans as the fan drive gear box cannot be seen below the fan covers (they sit under a sheet metal shroud).
ECA resin units which come with the fans, I have made these units with pc fans and flat plasticard on previous builds and they looked fine but the ECA are the dogs dangly bits! The noise of the fans ie all four sound good to, they have to be engine revs proportionate though. 8)
Steve Norris
Has liked: 8 times
I am interested to see how you get them to run proportional to the engine revs.
Has liked: 1421 times
Been liked: 1603 times
Ahem ;-)
viewtopic.php?f=4&t=4181
Adrian
Steve Norris
Has liked: 8 times
Hi Adrian
Interesting, I have one of your modules that I put away for the Tiger 1 build. So are you saying I can link 4 x 24v fans in series with smoke fan and they will run proportionally when the engine sounds are played.
A very quick and effective way to drive the fans proportionately is to simply connect the fans directly to the smoker rectifier, or fit another dedicated rectifier from the other main drive motor. 8)
As the fans run on such low current they kick in long before the main motor begins to turn, and if the TX is set up correctly it's possible to rev the engine and so energise the fans without the vehicle moving at all, then a little more TX input and the tank is moving with the fans accelerating nicely......or you could install one of Adrians units to do all this for you.
Glen Clark
Has liked: 19 times
Been liked: 160 times
Post by Glen Clark »
This will be good.😊I'm hoping to do some upgrades and weathering later once I've crawled over other people's Tigers looking for ideas.Seeing mine is the first one I've built I have no real idea what I'm doing.
Good luck and I can hardly wait.
Glen.
Bless you Glen, no pressure then? 8)
Spent the last part of yesterday unpacking and de-burring the hull plates.
Nothing terribly exciting but very necessary all the same.
florian rudolf
Has liked: 294 times
Been liked: 641 times
Post by florian rudolf »
Nice job Phil,
looking forward to see your report. - Lokking specialy at your engine build. ;)
Brian Ostlind
Has liked: 971 times
Been liked: 2066 times
Post by Brian Ostlind »
That’s a familiar view! I am looking at your workbench for tips now.
