Brian Ostlind
Has liked: 971 times
Been liked: 2066 times
Post by Brian Ostlind »
Does this look right?
I am test fitting these screens but they are too big and rest on top the square bolts. Am I supposed to trim the screen to fit or let it rest on the bolts?
Has liked: 775 times
Been liked: 1741 times
Maybe you need to bend the edges a bit more. Just a thought.
David Stewart
Been liked: 11 times
Post by David Stewart »
Hi Brian
When I fitted them on my intake grills I folded them down so they fitted past the bolts, this required a little bit of trimming.
What I think your supposed to do is fold them 90 degrees so the mesh sits atop of the intake, that way it also give you clearance to fit the finer mesh if so desired.
Armortek 2010 Mid Tiger 1
Tom OBrien
Has liked: 5 times
Been liked: 67 times
Post by Tom OBrien »
I couldn't figure out how the crews fit the screens onto the grills, so I imagined how I would do it in the field.
I simply welded the mesh to the grills so that it held the screen securely. Crude, but effective, I guess.
I suppose the mesh got bashed about regularly in the field, trod on and such, and occasionally replaced or repaired.
Been liked: 1644 times
trim to fit, and hold on with thin wire loops around both the mesh and the grill, not pulled to tightly, some small weld points all around the edge of the mesh, kent wiik has posted on this subject before, i am not sure if this is a factory fitting or a field mod but there are photo's on this subject here on the forum, regards simon.
Brian Ostlind
It’s running more or less perfect at the moment. The only thing I hate is one sides tracks look too tight. It really thrashes and tears it up now! I’ll regroup and put the rest together now.
[youtube][/youtube]
Brian Ostlind
This front end just looks so good.
Brian Ostlind
Shaping up.
Good to see you back at it.
Brian Ostlind
getting inspiration...
adding components...
Brian Ostlind
put a screw behind the visor to hold it up...
Brian Ostlind
Brian Ostlind
Brian Ostlind
fenders look good...
Glen Clark
Has liked: 19 times
Been liked: 160 times
Post by Glen Clark »
Looking good Brian,nice to see you back.
Glen.
