Sherman Aerial
Dale jordan
Been liked: 423 times
Sherman Aerial
Post by Dale jordan »
Yesterday I had my first day off in weeks . So I turned on the lathe , and made a flexiable U.S sherman Aerial base . Dale
Dale jordan
Dale jordan
Plus I turned up the barrel end DIA 12.5 mm
Dale jordan
Dale jordan
Dale jordan
I'm going to add some brass grab rails around the sides of the turret to hang back packs and stowage . Dale
Has liked: 1341 times
Been liked: 1538 times
That's a neat piece of turning :D
Did you fit a plug into the barrel end as it looks a smaller diameter than the threaded end on mine :?:
Has liked: 118 times
Been liked: 752 times
Dale,
Nice bit of work on the antenna mount. I'm planning a similar spring loaded one myself. Will this be the RC antenna? Or just for looks? If it is the RC antenna, do you insulate it from the tank turret? Like thread it into a piece of delrin plastic?
Your Sherman is looking great, I can't wait to get back on mine! I have some cool detail parts planned for it.
Dale jordan
Adrian the end fits inside the barrel . Bob the antenna is only for looks as I will us a 2.4G radio set ... Dale
Dale, do you have a colour scheme picked out for the Sherman yet ?
