I have just been trying to install the steering linear actuator and cannot get the steering into a straight ahead position.
I first connected the actuator to a receiver and powered it to its mid travel position, then attempted to connect it to the steering arm.
I found that the actuator was about 1/4 inch to long. Has anyone else had this problem and what was the cure.
Steering actuator
- Has liked: 8 times
- Been liked: 697 times
- Has liked: 2267 times
- Been liked: 7152 times
Re: Steering actuator
Hi Steve, I have not had that problem to that degree, maybe a few mm out. You could try repositioning the steering arm by rotating the track rod, this may point the steering in the wrong direction though, more drastic would be to heat the steering arm and reset to your required position (keep a record of the original angle in case you need to put it back ).
The actuator is self centering so that should always be at the mid point, check you TX settings, you may be able to move the center point to where you want it that way.
Maybe post a photo, you can email me if you would rather.
Regards Phil
Regards Phil
- Has liked: 294 times
- Been liked: 640 times
Hello Steve, I did not have the problem either. the actuator always automatically returns to the 0 position. fine adjustment must then be done with the controler. check out your controler settings. Maybe you'll get a picture of the complete steering setup.
