Florians FAMO build
florian rudolf
Has liked: 292 times
Been liked: 639 times
Re: Florians FAMO build
Post by florian rudolf »
Phil is right.
a) The secound position I did
b) don't cut the shaft nut.
You will see the hole on the top of the case over the shaft nut. I set the shaft nut in the rigt way (like I wrote it allready). Than make the hole about 3mm deeper in the brass, fixing the shaft nut with loctite, and install the pin as in the manual, also with loctite. so you have the right position for the shaft nut fixed.
Has liked: 2259 times
Been liked: 7147 times
Hi Florian, looking back through your thread and looking at your drive sprockets, have you bonded the rubber to the sprockets in that position ?
florian rudolf
Hello @ all,
after the x-Mass break, I'll continue my report. Made some details finish for the fame
framework is finished.
air oppenings
air oppenings
going with some electric
Gas tank on its place
beginning the engine room. Petrol filter
some work on the dashboard
brake and steering pins finished
brake handle
brake handle
The floor withj scale fasteners
florian rudolf
The special fasteners for the track chain, coming soon in end of March. so this one who want a set, and did'nt order it. Please PM.
I have a previos set...
looks realy good I think.
David Brady
Has liked: 164 times
Been liked: 701 times
Post by David Brady »
Nice details added florian
Very nice bonnet vents Florian.
florian rudolf
Thanks for the feedback. Its easyer to work on it, if you know that somebody appreciates it.
florian rudolf
Some more details. Now Iam on the window frame and the exhaust pipes.
Sorry for the bad photo quality, but you can see the rivets I have set and the new position for the handrail.
florian rudolf
I'm back, making some more details on may wind sheeld. Unfortunatly my window is broken while I install it in the frame. So I must built an new one in time...
I installed it provisionally, so not all fasteners are fixed, and I ahve'nt the wing-nut yet.
...is working. The nut in the middel, I change late into an wing-nut.
my solution
my solution
Original
Original
florian rudolf
Its could outside, so I worked a bit on more function details. Making the winkers.
Very nice detail piece Florian 8)
florian rudolf
Thanks Phil. I Hope its a good effect in the end.
florian rudolf
Yesterday I installed the mechanik for the winker and connect it with the winkers. So this work is completly done.
Looking good. Have you bonded the sprocket rubbers in that position Florian or are they loose?
florian rudolf
Hi Phil,
they are loose in time. Why do you ask?
I made the rubber with dubble tape, because I don't know the realy right position now.
