Phils Famo build
- Has liked: 293 times
- Been liked: 639 times
Re: Phils Famo build
Yes that's true Phil, but at the corners it will not be enough to get the rounding suitable. Made of sheet metal fenders can be provided with smashes to create a used look...
Today is my last working day. than hollyday till 07.01.19 so much time to build and creat some nice things
Florian
Florian
- Has liked: 2263 times
- Been liked: 7149 times
I,ve profiled one side of the fenders and I think it looks ok?
Hi Pfil,
that looks good on this side. How is the other side? - The inner side is verry round.
I have done both sides of this side, that's as much as I want to remove, it should look better when it's all the same colour!
- Chang
- Has liked: 15914 times
- Been liked: 426 times
Great looking on rounded fenders Phil.
Ever thinking of adding two short ribs and deepen the footstep on this area? Cheers,
Lerh Chang
Lerh Chang
Hi Chang,
that part you mean, is verry massiv, so I'm going to mill off all the stuff inside this part. The stepp is than a hole. Later I mill the smal stripes...
Much work to do..
Much work to do..
Hi Chang, that step hole will need milling, I may deepen it and and paint the hole very dark inside, are you going to round off your fenders? There are lots of rivet details on the fender which also need adding, I will add the two ribs.
- Brian Ostlind
- Has liked: 969 times
- Been liked: 2066 times
Cheers mate, heres some more.
Hi Phil,
You have seen the problem with the m4.... you took put the braket? Is there not too less drill in the metall to tighten the mudgaerd enough?
Florian
Florian
Hi Florian, there's enough metal in the m3 clearance hole to tap an m4, so I will drill an m4 clearance from below in the fender and fit an m4 button head that way.
More detail for the fenders.
- Steve Lewington
- Has liked: 8545 times
- Been liked: 283 times
Hi phil
love the use of plasie card mate
nice one well done loving the build.
steve
steve
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
No respite.
No forgiveness.
Many thanks Steve and all the followers that click the like box! Some examples of what I have planned for more detail below.
- I love this weathering but it may not scale so well, we will have to wait and see.
- famofd_1.JPG (77.27 KiB) Viewed 1617 times
- da03554381b27e72fbed05fa09708572.jpg (31.71 KiB) Viewed 1617 times
Last edited by Phil Woollard on Sat Dec 22, 2018 10:34 am, edited 1 time in total.
- Been liked: 571 times
