Phils Famo build
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Re: Phils Famo build
Post by Brian Ostlind »
Cool!
Has liked: 794 times
Now you see it, now you don't.
When I looked at the second photo, I said what happened to the speaker that was in the first photo.
Excellent hiding place.
Has liked: 2282 times
Been liked: 7196 times
I do like the open engine bay look but bonnet on or bonnet off? There's a lot more detail involved with the bonnet off look but I think with the fan and generator spinning away nicely, all the fire wall details, tie rods and hoses it should look pretty good. Now what colours for the engine? I was thinking of field grey for the block with black rocker covers and flat aluminium for the ancillaries?
air filter.jpg (121.87 KiB) Viewed 1977 times
It would be nice if this is the last time the engine goes in but I expect it will have to come out yet again.
Lots of this work for me due to my dummy engine taking up the entire engine bay
Been adding a bit of pre shading to those areas that will be difficult to work on as the bodywork grows
Working out the steering column alignment, I need to get a dedicated steering wheel servo to not only function as in turn the steering wheel but to disguise the thing to look like the Famos steering box
Got a bit of the plumbing done today along with some of the control levers, wiring loom next.
I think I am quite happy with the colours overall, I even like the way the primmer is flaking off the fan belt.
Fitted the bulkhead to radiator tie rods
Not keen on the exhaust header as it looks to clean, so more work required there to tone it down
Chang
Has liked: 16586 times
Been liked: 487 times
Post by Chang »
Hi Phil,
Like the engine room adding. The two tie rods are must for mine.
What are the two round ring on the end, flat washer?
Lerh Chang :D
Hi Chang , yes they are simply flat washers, for more accurate detail you could add an oval washer with with two small bolts. You will find that leaving the tie rods " floating" ( around 8mm) it's easier to fit the main body .
Ref that long machined slot near the top of the firewall, I would think that was to aid in the locating of the work piece to be machined, There's no evidence of the slot anywhere that I can find, so it may need to be covered up?
Bonnet off?
Bonnet off?
Or bonnet on? I'm planning on having the front tilt (canvas) down with the bonnet (hood) off, along with the engine compartment sides stored in the rear.
Sorry more engine bay photos, that's the wiring loom done, I've gone for the older more exposed control box and starter solenoid as it's more interesting than a couple of black boxes, slightly over scale but needs to be robust enough to survive as a working model, a bit like the clamps to hold the plumbing and wires in place, that's the Armortek way :D it will last a life time.
I've also put the gusset supports in against the firewall. Now to the front hoses and then the steering box and servo.
I should get the linear actuator today along with the winch motion parts. 8) I need to see just how much room the L/A takes up before I make the steering box.
I think I will turn a nice big klaxon on the lathe, some examples have a newer horn but I think the old klaxon looks in period.
Brian Ostlind
We’re thise your model I thought it was the real one lol.
Thank you Brian! Have you been on the beer again? :D . Just had to post a pic of two very important things.
The linear actuator
The linear actuator
The klaxon
The klaxon
It took maybe 30 mins on the lathe but well worth the effort.
Brian Ostlind
Lol! I have not had beers just quickly posting in the middle of the night. Bleary eyes make it extra hard to differentiate the kit you have put together from an original. It’s looking better and better. Kudos!
Got it, best be careful with the messaging in the middle of the night, I was discussing tigers with a girl on a dating web site the other night ..........thinking I was on the armortek forum! Lol :oops:
You will love the kT Brian, it's a monster and will wreck your nice timber floors at home!
florian rudolf
Has liked: 297 times
Been liked: 645 times
Post by florian rudolf »
:lol: don't flirt with girls while working on Famo... Hihi
Your engine looks nice Phil. Cathing your photos to make my own ;)
In time I'm on my cabin floor, making it scale :)
David Brady
Has liked: 216 times
Been liked: 840 times
Post by David Brady »
Hi,
Adding some nice details phil.
florian rudolf
Hi Phil,
you installed the linear actuator allready... Do you know if this thing works with 5v or more? - You have the motion board, may you can look at the exit pin for the linear actuator?! ;)
Other question:
Do you know how many Ah power is the motor regulator? I thing 30Ah would be enought?!
Florian
