Phils Famo build
- Brian Ostlind
- Has liked: 976 times
- Been liked: 2068 times
- Has liked: 794 times
Re: Phils Famo build
Now you see it, now you don't.
When I looked at the second photo, I said what happened to the speaker that was in the first photo.
Excellent hiding place.
I do like the open engine bay look but bonnet on or bonnet off? There's a lot more detail involved with the bonnet off look but I think with the fan and generator spinning away nicely, all the fire wall details, tie rods and hoses it should look pretty good. Now what colours for the engine? I was thinking of field grey for the block with black rocker covers and flat aluminium for the ancillaries?
- 3507-2.jpg (49.84 KiB) Viewed 1976 times
- air filter.jpg (121.87 KiB) Viewed 1976 times
- afa0b00ed9010bd251036598240d9df2.jpg (73.78 KiB) Viewed 1976 times
It would be nice if this is the last time the engine goes in but I expect it will have to come out yet again.
Got a bit of the plumbing done today along with some of the control levers, wiring loom next.
- Chang
- Has liked: 16582 times
- Been liked: 487 times
Hi Phil,
Like the engine room adding. The two tie rods are must for mine.
What are the two round ring on the end, flat washer? Cheers,
Lerh Chang
Lerh Chang
Hi Chang , yes they are simply flat washers, for more accurate detail you could add an oval washer with with two small bolts. You will find that leaving the tie rods " floating" ( around 8mm) it's easier to fit the main body .
Ref that long machined slot near the top of the firewall, I would think that was to aid in the locating of the work piece to be machined, There's no evidence of the slot anywhere that I can find, so it may need to be covered up?
Sorry more engine bay photos, that's the wiring loom done, I've gone for the older more exposed control box and starter solenoid as it's more interesting than a couple of black boxes, slightly over scale but needs to be robust enough to survive as a working model, a bit like the clamps to hold the plumbing and wires in place, that's the Armortek way
it will last a life time.
I've also put the gusset supports in against the firewall. Now to the front hoses and then the steering box and servo.
I should get the linear actuator today along with the winch motion parts.
I need to see just how much room the L/A takes up before I make the steering box.
I think I will turn a nice big klaxon on the lathe, some examples have a newer horn but I think the old klaxon looks in period.
- Brian Ostlind
Thank you Brian! Have you been on the beer again?
. Just had to post a pic of two very important things.
- Brian Ostlind
Lol! I have not had beers just quickly posting in the middle of the night. Bleary eyes make it extra hard to differentiate the kit you have put together from an original. It’s looking better and better. Kudos!
Got it, best be careful with the messaging in the middle of the night, I was discussing tigers with a girl on a dating web site the other night ..........thinking I was on the armortek forum! Lol
You will love the kT Brian, it's a monster and will wreck your nice timber floors at home!
- Has liked: 297 times
- Been liked: 645 times
Your engine looks nice Phil. Cathing your photos to make my own
In time I'm on my cabin floor, making it scale
- Has liked: 216 times
- Been liked: 840 times
Hi Phil,
you installed the linear actuator allready... Do you know if this thing works with 5v or more? - You have the motion board, may you can look at the exit pin for the linear actuator?!
Other question:
Do you know how many Ah power is the motor regulator? I thing 30Ah would be enought?!
Florian
Other question:
Florian
