Florians FAMO build
florian rudolf
Has liked: 292 times
Been liked: 639 times
Re: Florians FAMO build
Post by florian rudolf »
Hi Derek,
its Panzergrau from Revell
Derek Attree
Has liked: 218 times
Been liked: 178 times
Post by Derek Attree »
Hi Florian
Thanks for the information.
You are going to need a lot of those pots I think :shock: .
Has liked: 122 times
Been liked: 753 times
Florian
Nice work removing the machine mark on the wheels -it looks great! That's a lot of grinding!
Enjoying these FAMO builds - fantastic rig.
florian rudolf
Hello Bob,
Thank you for the praise. The Famo should be something special.
Has liked: 2259 times
Been liked: 7147 times
Morning Florian, a question, should our Famo have the two top vents in the bonnet?
florian rudolf
Yes Phil it have to tops, for front and loading area.
florian rudolf
@ all FAMO owners and screw interests, pleas note.
The special track links screws are availabal, but to thinks to note:
1. The delivery will be at latest in March 2019.
2. The price for 250pcs. would be 41,00€ + shipping.
So pleas note, if you want to get the set send me an PN or email:
hot.rod32@web.de
Chang
Has liked: 15797 times
Been liked: 424 times
Post by Chang »
Two top vents on the bonnet shown on someone's scratched-built FAMO.
(See http://www.sixtharmygroup.com/portal/viewforum.php?f=23)
florian rudolf
Hi Chang,
thanks for your image. My plan is to build it like this. But unfortunalty its a long time to come to this piont. Maybe in Febr. I am on this point. In time lots of other work to do.
florian rudolf
Good morning all,
a view day bevore I posted al little construktion problem. I'll be back with my solution.
You see at the attachments the bracket to fix the track mudget on front under the body bottom. The problem is, that you cant fix the mudget, because you can't hold the nut for tithening. So I take now M4 fasteners for tithening the mudget.
So I drilled a thread (M4) in the bracket, and make two other holes for M3 countersunk screws, to fix the bracket.
florian rudolf
On weekend I worked on my winch. Its now finised. Photos comming soon.
Nice mudguard fix Florian, just make sure the tracks can't catch the cap heads, square head bolts and track links can stop a motor dead, especially when the road wheels suspension is at max deflection!
I get my winch end of next week so I will apply your fix to that also, keep up the excellent work regards Phil. :D 8)
florian rudolf
Yes Phil I thought about that track problem... The screw is verry flat (looks bigger on the photo), so that will be work.
florian rudolf
Hi guys,
it takes a little time to prepair the trackwheels, but now I could finish my trackwheel and framework... It looks good I think.
Making the fasteners for the outer wheels
All I need
All I need
Chang
Post by Chang »
florian rudolf wrote:
Mon Nov 26, 2018 10:42 am
Hello Famo owners,
I continued to work on the winch. here it needs some rework, so that the winch works well.
Hi Florian,
Regarding the re-work on the winch, what are the details of re-works? I have two questions here:
Question (A),
The CS0574 and CS0511 are together with the winch case here.
I am confused with the diagram in the manual:
(1) CS0574----One end with a M4x4 grub hole. Should it be on the left hand side of the hole in the winch case, or the other way around?
(2) CS0511----One shaft is shorter, and the other one longer. Which side should be into CS0574?
Question (B),
I've found that without CS0511, the shaft nut (CG0249) can easily be locked tight into the winch case. But became impossible when CS0511 is in position. Is there any re-work needed?
Sorry about the long words.
With regards,
Lerh Chang
