Hi Adrian
I forgot to add the rinse in clean water before drying, just to get the soap off.
Liam
Media blasting
- Been liked: 315 times
- Has liked: 1480 times
- Been liked: 1686 times
Re: Media blasting
So the cabinet and compressor arrived this morning
After a few false starts, due to neither arriving with an air line - thank heavens for the local Screwfix
- I've managed to get it plumbed in and tested.
This is a couple of track links, showing the before and after:
Still not sure I'm getting the pressure regulation right on the compressor, so taking it gently at the moment.
- Has liked: 17 times
- Been liked: 7 times
Re: Media blasting
So am I. I'm much more confident I'll be able to use some of the 70 odd that were saved from the fire.sean kerambrun wrote: ↑Mon Nov 19, 2018 10:13 pmimpressed how good the track links came up .. look new
Re: Media blasting
Hit a bit of a speed bump today
There is no moisture trap between the compressor and the blasting cabinet, and today I was having to clean out the nozzle of the gun at regular intervals. After a few minutes use, I was finding that there was a build up of gunky sand around the inside of the nozzle, which eventually stopped the gun picking up any more sand.
I'm going to buy a moisture trap to fit to the side of the cabinet, as I was surprised when I disconnect the air line that there was water dripping out of the end of it. One of the problems with using it in damp conditions I suppose.
I wonder if the media will dry out if I put it in oven tins in the airing cupboard ?
