- Brian Ostlind
- Has liked: 972 times
- Been liked: 2068 times
I am covering the gravel on my property with decomposed granite.
- Brian Ostlind
Back inside table is a perfect fit. I am waiting for a small motorcycle jack to get delivered next to boost it up off the table.
- Has liked: 5 times
- Been liked: 67 times
Table looks great. I'd be curious to see the motorcycle jack.Brian Ostlind wrote: ↑Sat Nov 10, 2018 8:09 pmBack inside table is a perfect fit. I am waiting for a small motorcycle jack to get delivered next to boost it up off the table.
I have crushed granite on some of my property but it's 3/4 inch and too large to drive in without having the tracks pick it up and get stuck in the running gear. I think 1/4 inch or smaller crushed stone would work. Sand would be the best.
- Brian Ostlind
Inspection and alignment after one hours driving time. I am putting a washer under the wheel retaining piece on the hub so the last roadwheel has 1mm of float. I am also going to re install the right sprocket a little wider out. See the paint wear on the inside teeth of the sprocket and the face of the front inner roadwheel indicates the tracks are pushing in on the wheel and sprocket. The idlers are wearing evenly so it’s probably correct.
- Brian Ostlind
i did a little test drive and it wasn’t any better so I might go the other way with things and see how it goes.
- Brian Ostlind
Heading out for the next test drive. I think I have all the issues worked out. I’ll post a video.
- Brian Ostlind
I think I got it all set up nicely now but my batteries died lol.
...the sad slide down the hill was weird the red light on the remote start was blinking as it rolled down. Is that some kind of feedback from the motor?
When you tow the tank do you want the remote start on or off with the batteries charged or dead?
[youtube][/youtube]
[youtube][/youtube]
- Brian Ostlind
Photo etch bending while batteries are charging.
- Brian Ostlind
Seems to run great now with just careful driving.
[youtube][/youtube]
[youtube][/youtube]
- Brian Ostlind
I drove some more now I’m taking it apart because I think my sprocket needs more chamfer.
- Brian Ostlind
- Brian Ostlind
- Has liked: 781 times
- Been liked: 1745 times
I am no expert, but looking at that last video gave me the impression that the tracks could be loose. Maybe experimenting with tensioning the track with the idler adjustment or maybe removing a track link.
Just a thought.
Just a thought.
- Brian Ostlind
Vince, there are a lot of variables and right now I am moving ROADWHEELS out with a crowbar from inside the hull. When I get them lined up better I will tighten the track.
- Has liked: 1442 times
- Been liked: 1611 times
> haha this thing is awesome!
The addiction is taking hold
Don't forget that when you add the turret the weight will compress the suspension and make the tracks looser.
