Martin's Jagdpanther
- Martin Hofmann
- Has liked: 149 times
- Been liked: 1898 times
Re: Martin's Jagdpanther
Hi Marco,
i use Mr. Surfacer 500 and mix it with some sand from a pet-shop with a diameter of approx. 90 mikrometer. After the first layer there comes two layers with Mr. Surfacer without sand to smooth the surface a little bit.
Here are some new photos from the roof with the covers and the o-rings....
Regards Martin
- Been liked: 1661 times
- Martin Hofmann
Hi Simon,
many thanks for your compliments.
Here are some more photos of the covers on the roof and the first screws mounted on the Maybach motor!!!
Regards Martin
- Marco Peter
- Has liked: 1438 times
- Been liked: 788 times
- Martin Hofmann
Hi Marco,
thank you for your "WOW"
after a very long time of doing anything at the Jagdpanther i start again with the next mounting process.
Here are the next photos of the hull and the covers on the bottom and the side. They are all scratch built.
Regards Martin
- Has liked: 132 times
- Been liked: 784 times
- Martin Hofmann
Hi Bob,
thank you for the nice words. Here are the next covers, the first swing arms and the first welding seams.
I had closed the corners in the sheet over the tracks with another sheet and two srcews. The headlight on the mudguard got a fake cable and some rivets onto the hinges.
Regards Martin
- Martin Hofmann
- Has liked: 732 times
- Been liked: 333 times
Fantastic detail Martin!
You are making progress at a pace like you had nothing else to do, which I know is NOT the case!
Amazing!
I hope to see it when ready!
![Shocked :shock:](./images/smilies/icon_eek.gif)
- Martin Hofmann
Hi Chris,
thank you for your comment. Yes it works, but not as fast as i would like
. Here are some more details which are very time consuming. But I have to have these details because I am very in love with details.
Regards Martin
- Martin Hofmann
Hi Simon,
thanks a lot, your comments are very welcome.
Here begins the first step of weathering and aging of the bottom and the side plates, before mounting the swing arms and the wheels.
Regards Martin
- Martin Hofmann
In the mean time i prepared the idler wheels and the sprockets for mounting. Also the final drive housing is ready after weathering.
Regards Martin
- Martin Hofmann
Now it is time to make some details onto the motor. Here are some photos from this procedure.
Regards Martin
- Martin Hofmann
