- Has liked: 2267 times
- Been liked: 7152 times
The one on the end of the final drive shaft under the sprocket cap, it sits up against the taper bush, the last thing to do up before the sprocket cap goes on
- Brian Ostlind
- Has liked: 971 times
- Been liked: 2066 times
ROADWHEELS: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
These wheels cane out amazing. So excited that I got them right!
- Brian Ostlind
Test drive; Brian's 2017 NO. 10 LATE TIGER 1 BUILD
It goes!
Video:
[youtube][/youtube]
Video:
[youtube][/youtube]
Last edited by Brian Ostlind on Wed Oct 31, 2018 12:48 am, edited 2 times in total.
- Has liked: 775 times
- Been liked: 1742 times
Congratulations Brian on reaching that milestone. It must feel good to see it move.
- Has liked: 130 times
- Been liked: 782 times
Fantastic Brian,
Your painted tracks look awesome! I love the color and weathering on the wheels, Super! Great milestone - Like the birth of a baby!
Hi Brian
In the video, are you using 96 track links on each side?
- Brian Ostlind
Thanks Brian.
Which two Spektrum receiver channels did you use?
- Brian Ostlind
I am using a Futaba radio. I modified the throttle stick to spring loaded center return.
Vince Cutajar wrote: ↑Tue Oct 30, 2018 10:01 amThanks Brian.
Oh. I thought you were using a Spektrum setup. Do you remember which two channels you are using; e.g. Aileron, Elevator etc.
- Brian Ostlind
The left speed control should be in the throttle stick and the right one should be on the elevator. I did use a spectrum radio one time because my Futaba radio came with the wrong receiver. I only bought the spectrum radio for the bench test The Futaba radio is superior because the option to modify the throttle stick with Futaba factory parts but I origibally couldn’t get it to work with the receiver it came with (t-fhsss.) After I ordered an s-fhss receiver I got it working and used it on my test drive. I recommend the Futaba mainly because the factory spring modification for a center return throttle stick.
Thanks a million Brian for your help. Pleased to say that I managed to bench test the R/C equipment with the motion control module and the motors.
- Brian Ostlind
I am pleased to have got this far in 5 months. I have done lots of experimenting and now am happy with my process so I think it will speed up a bit.
- Brian Ostlind
- Has liked: 729 times
- Been liked: 332 times
Ah, arranging with tiger food already! Good thinking! You will need 5,71 of those to match...
